#131524 - 18/12/2002 18:54 no hard disk found contact support
kswish0
Loc: Virginia, USA
I got the dreaded message today when I started my car on the way home from work. Tried several reboots and that didn't work. When I got home, I took it all apart to check the connections and everything seems to be making a good connection. Both of the hard disks are spinning up when power is applied. and the serial boot log is showing that both hard disks are found. Here is a copy of the serial output...
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg51-hijack-v300 ([email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Wed Oct 16 19:33:51 EDT 2002
empeg-car player (hardware revision 9, serial number 40104270)
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9a38c
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2100AT, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:a
e
Partition check:
hda:hda: read_intr: status=0x59
hda: read_intr: error=0x04
ide0: reset: success
end_request: I/O error, dev 03:00 (hda), sector 0
unable to read partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
What is causing this and how can I fix it?
#131525 - 18/12/2002 22:27 Re: no hard disk found contact support [Re: kswish0]
One of these things is causing it, and if you follow that link, you can also get ideas on how to fix it.
#131526 - 19/12/2002 12:55 Re: no hard disk found contact support [Re: kswish0]
elvis
Loc: Arizona USA
Dry solder joints where the IDE connector joins to the motherboard
It seems to be the most fasionable problem of late. One of mine has this issue. I'd suggest emailing David about it. Don't expect a quick response though; repairs are closed for the holidays (And I'm without my empeg !#$!$!#$!). If you haven't done the IDE cable swap, it's worth it to try that first.
Elvis
