#131868 - 22/12/2002 23:27 RW fails.....
lectric
Loc: New Orleans, LA
Ok, I was mucking about, installed preinit v.7, made the /programs0 and /programs1 directories, but forgot to make /programs0/preinit.d. Now I get this and cannot change to R/W mode... help!
empeg:/programs0# rw
empeg:/programs0# rwm
mount: can't find /drive1 in /etc/fstab or /etc/mtab
empeg:/programs0# mkdir preinit.d
mkdir: cannot create directory `preinit.d': Read-only file system
#131869 - 22/12/2002 23:28 Re: RW fails..... [Re: lectric]
lectric
And what is site rw? I get:
empeg:/programs0# site rw
bash: site: command not found
#131870 - 22/12/2002 23:39 Re: RW fails..... [Re: lectric]
lectric
Nevermind..... got it. Ran a manual fsck on it, and I can mount fine now. Uh.... thanks!
#131871 - 23/12/2002 10:53 Re: RW fails..... [Re: lectric]
Loc: Los Angeles, CA
the rw and rwm scripts do not include the procedure to mount the /programs0 and /programs1 directory. you need to do it manually if you want to write anything to those partitions.
#131872 - 23/12/2002 16:27 Re: RW fails..... [Re: image]
lectric
Hmmm... OK. Makes sense. TY
#131873 - 26/12/2002 14:29 Re: RW fails..... [Re: lectric]
genixia
If you used my script to create the /programsX partitions then it will have also created rop and rwp to manipulate them. It's not clear from your post whether you did or not.
#131874 - 28/12/2002 22:15 Re: RW fails..... [Re: genixia]
lectric
I did, and they didn't seems to work for me. Will try again tomorrow and repost. Thanks so much, btw!
