#133571 - 08/01/2003 10:29 IDE Cable
mkaye
OK, call me an idiot But in an attempt to replace a faulty Travelstar I ripped the IDE connector off the end of the cable in my MKII. I'm just a hamfisted Yorkshireman Anyway, I have a replacement drive ready to drop in, but need a new cable. Can someone help me out with a part no. and supplier?
M
---- MKII #080000528 - 40Gb Blue
#133572 - 08/01/2003 10:49 Re: IDE Cable [Re: mkaye]
Greetings!
Custom cable (length between connectors). You might want to email support or build your own. If it is any consolation, I did the exact same thing the first time around, but was able to squeeze the connector together and use some hot glue to fix it.
#133573 - 08/01/2003 11:37 Re: IDE Cable [Re: mkaye]
Is there anything I could change in the Drive Upgrade Guide that would have prevented you from doing this?
#133574 - 08/01/2003 12:31 Re: IDE Cable [Re: mkaye]
David
Loc: Cambridge
If you damage the cable, a replacement is 15UKP including postage. email [email protected] for details.
