#136398 - 22/01/2003 12:27 date changing to 2034
eliceo
I looked through faq and searched the bbs, I couldnt find much. My player is running hijack v 300 . The day and time seem to be working fine but the player will change to the year 2034. Re adjusting the year works but it changes back a few boots later, is this a known bug ? Has anyone found a way to fix this?
#136399 - 22/01/2003 12:38 Re: date changing to 2034 [Re: eliceo]
#136400 - 22/01/2003 12:42 Re: date changing to 2034 [Re: tfabris]
eliceo
the clock does keep time well enough, but just realized date and year arent right. Its a riocar as well.
Edited by eliceo (22/01/2003 12:43)
#136401 - 22/01/2003 14:00 Re: date changing to 2034 [Re: eliceo]
rtundo
Loc: Albany, NY
I knew the empeg did a lot of things but a time machine as well??
#136402 - 22/01/2003 14:24 Re: date changing to 2034 [Re: rtundo]
Oh yeah, I should have asked him if it was installed in a DeLorean.
#136403 - 22/01/2003 17:20 Re: date changing to 2034 [Re: eliceo]
FlibblE
Loc: UK - NE Wales
Mine did something similar over new year. I went away for a week, came back and it had some crazy date like July 2034 (can't quite remember exactly) I thought it was just because I hadn't turned it on for a bit and it had been kept in a cold place (locked in a boot/trunk), so I thought nothing more of it - it hasn't done it before or since though.
#136404 - 22/01/2003 17:42 Re: date changing to 2034 [Re: FlibblE]
Pretty sure that 2034 is where Unix date/time rolls over. It sounds like when reading the time, the processor is getting all 1s or somthing like that. I assume the clock chip is external in empeg?
Unix date/time is a signed 32 bit number meaning a maximum of roughly 2 billion seconds or 68 odd years. With an epoch of Jan 1 1966, that makes it roll over in 2034.
Sounds like hardware could be a prob.
Edit: Unix date/time epoch is actually jan 1 1970 but I'm pretty sure I'm on the right track.
Edited by Shonky (22/01/2003 17:44)
#136405 - 22/01/2003 17:47 Re: date changing to 2034 [Re: Shonky]
Daria
time rollover would be 2038.
#136406 - 22/01/2003 18:20 Re: date changing to 2034 [Re: Daria]
Yeah that makes sense BUT the Unix date rollover is definitely 2034.
Perhaps my understanding of how the 32 bits is used is wrong. Perhaps they use 6 bits = 64 years which would make 2034 right.
#136407 - 22/01/2003 18:32 Re: date changing to 2034 [Re: Shonky]
Nope. 03:14:07, Tuesday, January 19, 2038 UTC. Of course, by then, hopefully, we'll all be running 64-bit Unix systems that store the number of seconds past 1/1/1970 in a 64-bit integer that will require nothing more than a recompile of affected software.
Of course, then we'll have to do it all over again by 15:30:08, Sunday, December 4, 292277026596. I guess there's no perfect solution.
#136408 - 22/01/2003 18:43 Re: date changing to 2034 [Re: wfaulk]
OK correct you are but the time function overflows in 2034.
September 30, 2034 - Overflow of Unix time function
January 19, 2038 - Overflow of Unix systems
#136409 - 22/01/2003 21:39 Re: date changing to 2034 [Re: Shonky]
Daria
Yeah, that could be relevant here.
#136410 - 23/01/2003 09:00 Re: date changing to 2034 [Re: Shonky]
I can't find much more info about this 2034 date than rote repetition. The only site I can find that says anything more says:
    2034-09-30 Sat - Time overflow in some ancient UNIX, which was fixed long ago. Genuine, but no longer significant. See 2038.
Wait. Here's one that says:
    September 30, 2034 - UNIX time function overflow per USAF website (May be one of those nasty site-specific dates)
I think that we can both agree that the problem in 2038 is that a signed 32-bit integer will no longer be able to contain the number of seconds after 1969, right? Well, my Solaris man page for time(2) says:
    The time() function returns the value of time in seconds since 00:00:00 UTC, January 1, 1970.
which seems like the same description to me.
#136411 - 23/01/2003 10:01 Re: date changing to 2034 [Re: wfaulk]
Some really old Unixes didn't have the epoch in 1970. I couldn't find an online reference to this, but in The Clock Of The Long Now Ken Thompson or Dennis Ritchie or someone like that describes his mail archives from about that time, in which he's not sure exactly when they're from because "we changed the epoch around a few times".
#136412 - 29/01/2003 19:21 Re: date changing to 2034 [Re: eliceo]
utna
Loc: LA, CA
mine did the same thing, displaying 2034. pretty kooky.
riocar Mk2A 030102357 - 60 Gb
#136413 - 30/01/2003 00:09 Re: date changing to 2034 [Re: utna]
eliceo
no one seems to know, maybe a software thing.
#136414 - 30/01/2003 12:59 Re: date changing to 2034 [Re: eliceo]
lopan
Loc: Manassas VA
Happened to me too... weird...
Brett 60Gb MK2a with Led's
#136415 - 31/01/2003 09:43 Re: date changing to 2034 [Re: eliceo]
My spare empeg did this when I put it to use after it was unpowered for a few months. I just passed it off as a glitch due to the long time of being away from power, and haven't seen it again.
#136416 - 01/02/2003 10:37 Re: date changing to 2034 [Re: utna]
utna
Loc: LA, CA
Mine keeps doing it!
stopit!
is it perhaps a CMOS battery? does the Empeg have one of those?
#136417 - 02/02/2003 22:26 Re: date changing to 2034 [Re: utna]
lectric
Loc: New Orleans, LA
No battery, just a cap. Should last you a couple of weeks between charges.
#136418 - 03/02/2003 21:39 Re: date changing to 2034 [Re: lectric]
rbenech
Loc: CA, USA
Could a bad CAP be the cuplrit? Maybe (it's a long shot) our empegs got stuck with some poorly manufactured CAPS? (the article mentions that these typically are used to smooth out the power supply.
If you know where to look, check the capacitors for a slight buldge (maybe, the X is more defined) or brownish ooze.
Arcticles as reference:
http://www.spectrum.ieee.org/WEBONLY/resource/feb03/ncap.html
http://slashdot.org/articles/02/11/04/1751210.shtml?tid=137
I'm not trying to scare anyone and It's not even a 'hunch', just a odd-ball idea that somebody more talented than I could confrim or deny. Is there an easy way to test the CAP or outright elimitate it as being faulty?
I have seen only 1 example of a bad CAP (and it was on an IBM motherboard - mentioned in the article)...
Ryan here... Empeg [08000462] 40 Gig with Subaru WRX sport wagon attached... (still! pending memory + LED upgrade, sheesh, I've been sitting on my ass for years)
#136419 - 04/02/2003 02:14 on a scale of 1 to plausible... [Re: rbenech]
utna
Loc: LA, CA
i don't think it would be a bad capacitor. from what i've read, the issues with bad capacitors involve using generic components in the manufacture of the capacitors. I have a feeling that the Sonicblue/RIO/empeg people did not skimp on parts. but then again, it is reading 2034...
