#136508 - 23/01/2003 02:36 Preinit help - URGENT!!
furtive
I'm in the middle of installing Preinit. I've followed the instructions on the website, and so have done this:
ftp -s:install.ftp <empeg-hostname>
mkdir /programs0
mkdir /programs1
mke2fs /dev/hda2
mke2fs /dev/hdc2
mount /dev/hda2 /programs0
mount /dev/hdc2 /programs1
Now when I try to make my drives read only (ro or rom) I get this error:
mount: can't find /drive1 in /etc/fstab or /etc/mtab
What have I done wrong, and how do I fix it?
Thanks.
Rio Karma - now on ebay...
#136509 - 23/01/2003 03:27 Re: Preinit help - URGENT!! [Re: furtive]
furtive
My second drive is not hdc2, but is hdb2 apparently
Not sure why, but maybe this should be reflected in the instructions somewhere???
I get this error:
mke2fs /dev/hdb2
mke2fs 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
Could not stat /dev/hdb2 --- No such file or directory
The device apparently does not exist; did you specify it correctly?
And I still get the error above as well.
Edited by furtive (23/01/2003 05:34)
#136510 - 23/01/2003 09:04 Re: Preinit help - URGENT!! [Re: furtive]
That's odd. Usually both hdb2 and hdc2 exist, both pointing to the same thing, for the sake of consistency with the MkIs.
Have you installed other hacks?
#136511 - 23/01/2003 09:24 Re: Preinit help - URGENT!! [Re: wfaulk]
furtive
All I've got installed is Beta13-Dev, Hijack, and the games that I am trying to get onto the Hijack menu.
#136512 - 23/01/2003 12:17 Re: Preinit help - URGENT!! [Re: furtive]
genixia
The Mk1 empegs had 2 ide channels, so disks would be /dev/hda and /dev/hdc.
The Mk2 empegs only have 1 ide channel, so they are /dev/hda and /dev/hdc
However, the Mk2's have had the device node for /dev/hdc changed to point to what would normally be /dev/hdb. This enables Mark2 software to be consistent with Mark1 software..
But that shouldn't be the cause of your problem;
What does cat /etc/fstab reveal?
#136513 - 24/01/2003 01:38 Re: Preinit help - URGENT!! [Re: furtive]
mcomb
Loc: San Carlos, CA
IIRC drive1 isn't in fstab as the player mounts it directly via its dev entry. I definitely remember adding it to mine after adding a second disk. So the question would be did this work before and if so, why?
-Mike
#136514 - 24/01/2003 01:43 Re: Preinit help - URGENT!! [Re: genixia]
furtive
empeg:/empeg/bin# cat /etc/fstab
# /etc/fstab
# <device> <mountpoint> <filesystemtype> <options> <dump> <fsckorder>
/dev/hda5 / ext2 defaults,ro 1 1
/dev/hda4 /drive0 ext2 defaults,ro 1 1
none /proc proc defaults
#136515 - 24/01/2003 14:16 Re: Preinit help - URGENT!! [Re: furtive]
genixia
Hmm, I saw the same thing happen to me once upon a time (I believe when I upgraded to beta13), and never really worked out what caused it.
Anyway, here's the fix:
rw
echo "/dev/hdc4 /drive1 ext2 defaults,ro 1 1" >> /etc/fstab
ro
It's *very* important to ensure that you use ">>" and not ">" in the above line. ">>" tells the shell that the input is to be concatenated (ie appended) to the existing file. ">" would overwrite the file completely.
If you're at all unsure, then perhaps backing up the /etc/fstab file first would be a good idea;
cp /etc/fstab /etc/fstab.bak
While you putting that line in, you might also want to consider also;
echo "/dev/hda2 /programs0 ext2 defaults,ro 1 1" >> /etc/fstab
echo "/dev/hdc2 /programs1 ext2 defaults,ro 1 1" >> /etc/fstab
which will make ({re|un})mounting /programs0 and /programs1 easier.
#136516 - 24/01/2003 17:09 Re: Preinit help - URGENT!! [Re: genixia]
furtive
I'll give it a go.
Many thanks.
#136517 - 25/01/2003 02:08 Re: Preinit help - URGENT!! [Re: genixia]
furtive
That seems to have done the trick
Out of interest, what do those commands do?
Thanks.
#136518 - 25/01/2003 06:08 Re: Preinit help - URGENT!! [Re: furtive]
mtempsch
They append the stuff inside the quotes to the /etc/fstab file. This in turn tells the system to automatically mount the file systems specified on the lines at boot (with default options, but read-only). It also simplifies later mounts by having the options set and which mountpoint and partition that belongs together, specified in advance.
If you had after boot unmounted the /drive0 partition, you can the mount it by simply saying "mount /drive0" instead of also having to specify the options, filesystem type and partition...
