#137881 - 27/01/2003 18:33 IE question
lectric
Loc: New Orleans, LA
Does anyone know how to make IE allow more than 2 downloads at a time? (Other than using a d/l manager)
#137882 - 27/01/2003 18:38 Re: IE question [Re: lectric]
Yeah, open up multiple IE windows to the same site and begin two downloads from each of those windows. At least that worked for me if I recall correctly.
#137883 - 27/01/2003 18:39 Re: IE question [Re: tfabris]
lectric
Doh... was hoping for a registry hack.
#137884 - 27/01/2003 18:48 Re: IE question [Re: lectric]
lectric
Figures... After 30 minutes of lookng, I finally found it, 2 minutes after I posted the question. Here
#137885 - 27/01/2003 20:00 Re: IE question [Re: lectric]
number6
huh, that Q article makes me laugh - to wit:
This procedure is for informational purposes only. Changing the maximum number of connections beyond two is a violation of Internet standards; Microsoft does not recommended this procedure for use outside closed networks.
Since when did Microsoft give a f_ck about anyone elses "Internet Standards"?!
#137886 - 27/01/2003 20:28 Re: IE question [Re: number6]
lectric
Tell me.
#137887 - 27/01/2003 21:25 Re: IE question [Re: number6]
Heh. Who said they were someone else's standards?
Oh wait, what am I saying, even that argument doesn't hold water. They don't even follow their own standards.
#137888 - 28/01/2003 04:54 Re: IE question [Re: tfabris]
RFC2616, section 8.1.4:
Clients that use persistent connections SHOULD limit the number of
simultaneous connections that they maintain to a given server. A
single-user client SHOULD NOT maintain more than 2 connections with
any server or proxy. A proxy SHOULD use up to 2*N connections to
another server or proxy, where N is the number of simultaneously
active users. These guidelines are intended to improve HTTP response
times and avoid congestion.
#137889 - 28/01/2003 08:35 Re: IE question [Re: Roger]
Loc: Los Angeles, CA
i find it so funny how they can comply with one standard, but not another.
#137890 - 28/01/2003 08:43 Re: IE question [Re: image]
That article was all born of some kind of misunderstanding, though; when it was on Slashdot none of the TCP gnomes who tried to reproduce it saw anything remotely similar.
#137891 - 28/01/2003 10:42 Re: IE question [Re: peter]
lectric
The only reason I want more than 2 is that I frequently download from more than 1 server at a time. And since my end is RARELY the bottleneck....
#137892 - 28/01/2003 11:09 Re: IE question [Re: peter]
TCP gnomes
What's color is a TCP gnome? How tall are they?
#137893 - 28/01/2003 17:44 Re: IE question [Re: peter]
yeah, they commented about that on the bottom of the page.
UPDATE: Since this post got Slashdotted, I've been getting a pretty fair amount of e-mail, suggesting that the behavior we observed here might be anything from T/TCP to HTTP/1.1 pipelining to delirium tremens. Well, I should point out that this phenomenon was something we observed in 1997, before HTTP/1.1 was in wide use; both the client and server were using vanilla HTTP/1.0. As it turned out, it was actually the NT stack that was causing this to happen-- it didn't matter what client or server software you used. It even happened with our home-grown network test tools.
It's entirely possible that Microsoft has changed the NT stack in recent iterations so that this doesn't happen anymore. But if you're trying to reproduce the behavior, use NT 4.0 machines for worst results.
