After a brief period of ownership with the Pioneer remote, I had the following problems :
1. The Pioneer remote secures to the steering wheel with a strap, which was never tight enough round the wheel shaft to stop it rotating when a button is pressed. Not good.
2. To avoid (1), I mounted the remote onto the steering wheel with 2 x M3 allen screws. Problem solved. Not bothered about hacking my car to bits cause its a shed, but you may feel differently about this
3. During an energetic 'reverse round a corner from a main road' manouvre, my hand caught the Pioneer remote on the steering wheel, causing the bracket (which is now screwed to the steering wheel) to snap. The remote has lived in my ash tray, unused, ever since.
4. Bought a tuner, used a sony joystick for remote control, and never looked back.
If I was buying again, I would personally give the kenwood - with its alternative mounting arrangement - a try.
