#142993 - 13/02/2003 03:17 Moderately concerned at this point....
Blipman
Loc: Melbourne, Australia
I have just replaced a faulty IDE cable (faulty batch, apparently) under warranty, and after putting everything back together, it won't turn on. When I plug it in the standby LED doesn't even light.
Can anyone suggest what may be the problem before I get onto technical support? Now, I'm sure the first thought in everyone's head is I must have bumped something while it's apart, but I have sufficient confidence in my abilities that I would be VERY suprised if I did (although I won't of course rule this possibility out).
My hope (!) is that it may be to do with the fact that it has not been plugged in for a few months.... is there some flash memory or something which has died without power over time? Unfortunately I didn't think to test it before opening to see that all was ok. Any way to force a cold reboot? Any other suggestions people can suggest would be met with open arms.... after having it out of action for a while I was really looking forward to cranking it up, and sending it under warranty (if they will even honour it now) from Australia will be a real drag.
Many thanks for any help you can offer.
Empeg guru powers, activate!
Ben
#142994 - 13/02/2003 03:19 Re: Moderately concerned at this point.... [Re: Blipman]
Sure you don't have the IDE cable off by one pin? I assume you didn't remove the display board cable, but if you did, is it off by one pin?
#142995 - 13/02/2003 12:48 Re: Moderately concerned at this point.... [Re: Blipman]
Yup, as I recall, the last person who reported a player-won't-boot-after-replacing-cable problem, it was either plugged in backwards or plugged in off-by-one-pin.
Remember that the display cable actually interferes a bit with the IDE cable connector, so it's easy to get things off by one even if you don't think you did. You've got to be extra careful.
#142996 - 13/02/2003 15:24 Re: Moderately concerned at this point.... [Re: Blipman]
decay
I might try to boot without harddisks... But, that's just me d=)
- Decay
#142997 - 13/02/2003 16:17 Re: Moderately concerned at this point.... [Re: tfabris]
Happy Birthday tanstaafl.
Perhaps not all drives look the same, but my 18 GB Travelstar actually looks more "correctly" plugged in when the connector is off by one pin. When that happens, you power up and... nothing happens.
#142998 - 13/02/2003 17:50 Re: Moderately concerned at this point.... [Re: tanstaafl.]
Blipman
Hmmm.... well, I was indeed a pin off on the cable which attaches to the board, so it now turns on. Huzzah! But, it doesn't get much further.... I can't hear any hard drive action, and after showing the boot animation, it just hangs here:
<img src=http://yoyo.its.monash.edu.au/~blipman/trash/empeg.jpg>
I assume something's still not right with the cables, or should it not even get this far if that's the case?
Confidence in my skills falling..... falling..... gone.
Ben
#142999 - 13/02/2003 19:23 Re: Moderately concerned at this point.... [Re: Blipman]
Plug the empeg into your computer with the serial connection and then use hyperterm or equivalent to look at what the empeg prints out on the serial port. Read this bit of the FAQ for exact details on how to do it. You don't need the developer version of the firmware loaded however as you're more interested in the boot up messages.
It should be a lot more informative about what's wrong. Paste it into a post on here so we can have a look at it.
- Trevor
#143000 - 13/02/2003 19:56 Re: Moderately concerned at this point.... [Re: Blipman]
Are you sure you weren't two pins off, and you only moved the connector over by one pin??
I seem to remember that one of my connectors (Sorry -- don't remember for sure if it was to the drive or to the board) showed two pairs of pins not covered by the connector when the connector was in the proper position.
#143001 - 13/02/2003 22:25 Re: Moderately concerned at this point.... [Re: tman]
Blipman
Ok, you asked for it
Connecting via hyper terminal as per tman's insturctions gives this:
e000 v1.04
Copying kernel...
Calling linux kerne
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v294 ([email protected]) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Sat Sep 21 11:00:35 EDT 2002
empeg-car player (hardware revision 9, serial number 40103373)
Command line: mem=16m
Memory: 15072k/16M available (928k code, 20k r
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=e7)
empeg usb initialised, PDIUSBD12 id ffff
USB: Non-standard request
... and continues ad nauseum.
Is that any help?
Ben
#143002 - 14/02/2003 05:15 Re: Moderately concerned at this point.... [Re: Blipman]
Um, that doesn't look good...
#143003 - 14/02/2003 05:51 Re: Moderately concerned at this point.... [Re: Blipman]
I'm guessing that you've blown one of the fuses on the board and that's whats making the empeg not work. It can't find the crystal semi audio chip and the USB chip. You can either try and replace the fuses yourself but it's quite fiddly surface mount work or send it in to be repaired.
- Trevor
#143004 - 14/02/2003 12:26 Re: Moderately concerned at this point.... [Re: Blipman]
Interesting. It's not getting far enough to even start to detect for the disk drive.
Unplug the drive cable completely, and then let's see a serial log.
#143005 - 14/02/2003 13:38 Re: Moderately concerned at this point.... [Re: Blipman]
schofiel
Could not find CS4231A (version=e7) < Oh Oh
USB: Non-standard request < Oh Oh 2
You have a damaged CS4231 chip, which brings down the power for the IDE, making it look as if the disk is not found.
Contact support.
#143006 - 14/02/2003 15:16 Re: Moderately concerned at this point.... [Re: schofiel]
genixia
Contact support.
Hmm... I thought you were support. I guess you meant "email support so I officially have to look at it"
Yeah, the missing CS chip worried me too. I didn't want to be the messenger with bad news though, and was hoping that maybe someone would know of an innocent non-support issue that could cause that.
#143007 - 15/02/2003 19:59 Re: Moderately concerned at this point.... [Re: genixia]
Blipman
Not sounding good, is it?
Ok, tried connecting via hyperterminal with the hard drive disconnected, and got this:
ÿIf there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
Memory: 15072k/16M available (928k code, 20k reserved, 360k data, 4k init)
empeg state support initialised 0089/88c1 (save to d0004900).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
Probing primary interface... (it waited here for several seconds)
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0d:2
d
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:05
I then tried plugging the hard drive back in again and turned it on, and bingo, hard drive noise! It stuck at the "Hijack v2.94 by Mark Lord" initial screen. Turned it off, then on again, and once more, hard drive noise, this time it made it to where it did before (the logo screen after animated logo). It flashes for the very briefest of time the "hard drive not found, contact support" screen (something left in memory?). Hyperterminal at this point produced the following:
e000 v1.04
Copying kernel...
empeg dsp initialiseduest
empeg usb initialised, PDIUSBD12 id 1012d request
USB:
empeg state support initialised 0089/88c1 (save to d0004a80).d request
empeg RDS driver initialised Non-standard request
empeg single channel IDEtandard request
Probing primary interface...ndard request
hda: ÆUÊIÔSÕ ÍHÍ2±0°AÔ                      , ATA DISK drive
USB: Non
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0d:2st
U
d:
Partition check:uest
hda: read_intr: error=0x10
hda: read_intr: status=0x59
ide0: reset: success
end_request: I/O error, dev 03:01 (hda), sector 0
> hda2 hda3 hda4
Press Ctrl-A to enter pump...X]]Y[\]fs: unable to read superblock
which is strangely different to what it was doing before. It consistently gets to this point now. The only mild comfort I get from all this is that at least the hard drive now spins up and does a small read or write when I turn it on.
Ben
#143008 - 15/02/2003 22:47 Re: Moderately concerned at this point.... [Re: Blipman]
genixia
Hmm... that makes me wonder if maybe the IDE was bringing down the CS chip, not the other way around.
But, I don't have the schematics for the player - I assume that Rob does.
#143009 - 17/02/2003 17:54 Re: Moderately concerned at this point.... [Re: genixia]
ISTR the 4231 is definitely on the 5v side of the bus (hence would be affected by a faulty HDD or cable fiddling with the signals). I think the USB slave *might* be too - don't have the cct diagrams to hand.
As the player works much better with the HDD not plugged in, I suspect:
- HDD
- Cable
- HDD header on PCB
Got another HDD to try it with?
#143010 - 17/02/2003 18:10 Re: Moderately concerned at this point.... [Re: Blipman]
ltd
You broke it Ben!!
