#145529 - 24/02/2003 13:28 Sony Stalk and Hijack 320
GeoffT
Loc: Coventry, UK
I've posted this in the bug report section but would also we interested to know if others are having the same problem.
I've just upgraded to Hijack 320 (from 283) to use the boot up volume facility (which works great -thanks Mark)
Unfortunately this seems to be having some strange effects on my Sony Stalk/ ir_translate settings.
The first thing is that both KBottom and KRear appear to program the same button (the top button of the group of 3 for a left mounted stalk). i.e if the ir-translate has KRear=xxxxx followed by KBottom=yyyyy the Rear button is programmed with yyyyy not xxxxx and the Bottom button is not programmed at all. Also the Vol down button now acts as play/pause for a single press and turns the player off for a long press.
VW Golf MKIV GT-TDI 130 MK2a 10GB blue
#145530 - 24/02/2003 13:31 Re: Sony Stalk and Hijack 320 [Re: GeoffT]
And, FYI, you'll most likely catch Mark's attention if you post Hijack information in the programming section...
#145531 - 24/02/2003 18:33 Re: Sony Stalk and Hijack 320 [Re: GeoffT]
Chuck
Volume Down appears to work correctly for me in it's default configuration.
These are the only mappings I use though:
[ir_translate]
00000010=0020df14 ;Stalk Left Side Button ---> Remote Info
00000014=00000004 ;Stalk Previous Knob ---> Front Previous
00000015=00000002 ;Stalk Next Knob ---> Front Next
80FFFFFF=0020DF0d ;Stalk Bottom Button ---> Remote Shuffle
00000035.T=0020df15 ;Stalk Shift Vol Up ---> Remote Visual (Tuner Only)
#145532 - 24/02/2003 18:41 Re: Sony Stalk and Hijack 320 [Re: GeoffT]
Exactly what is in your config.ini ?
