#146819 - 04/03/2003 14:02 play all songs
edsmiata
Loc: New Jersey
Does anybody know how, upon turning the unit on, I am able to queue all songs that have been loaded into the player? Do I have to copy all of the songs into a playlist to do this, or, from the Playlist menu, can I drill down to the first 'arrow' that appears on the screen to do this? I would think that my second suggestion should work, but when I do I never see the number of songs that I know have been downloaded on to the player appear on the screen.
Thanks for you help!
Ed
#146820 - 04/03/2003 14:06 Re: play all songs [Re: edsmiata]
Yes. Down-Down-Down puts all of the songs on the player in the running order.
How off is the number that shows up? If it's a few lower, then it's likely that you have songs that either got orphaned or you've got multiples of the same song in different playlists, but you're counting those multiple times.
So, what number do you expect and what do you see?
#146821 - 04/03/2003 14:15 Re: play all songs [Re: wfaulk]
edsmiata
Loc: New Jersey
In emplode i am seeing just over 3,500 songs. On the HU display i am seeing less than 2500. I hope I dont have that many duplicates!
#146822 - 04/03/2003 14:16 Re: play all songs [Re: edsmiata]
SE_Sport_Driver
Do you have any playlists set up as "ignore as child" ?
#146823 - 04/03/2003 14:28 Re: play all songs [Re: SE_Sport_Driver]
Good point. Some of my flags (although I don't think that one) got set even though I didn't do it. I think that that was a bug with jEmplode a while back.
#146824 - 04/03/2003 14:33 Re: play all songs [Re: SE_Sport_Driver]
edsmiata
Loc: New Jersey
honestly dont know..gotta check that out later!
Thanks!
#146825 - 04/03/2003 14:38 Re: play all songs [Re: edsmiata]
This is a FAQ Entry.
Also remember that you can't play a song from the "Playlists" menu unless it's... in a playlist.
#146826 - 04/03/2003 14:40 Re: play all songs [Re: tfabris]
I think I need to update that FAQ entry a bit, though, it gives "Wendy Filters" as an example of another way the number of tracks could be less. But there are others, so I'll link those too.
#146827 - 05/03/2003 02:05 Re: play all songs [Re: tfabris]
I have found another way I get differing numbers, although it doesn't really bother me.
If I turn shuffle off, and then down-down-down, I get 6876 tracks. Select shuffle random, down-down-down, I get 5692 tracks.
This puzzles me a little - as I'm not using wendys or ignore-as-child.
Any thoughts
#146828 - 05/03/2003 02:14 Re: play all songs [Re: frog51]
matthew_k
I'm sure there's a FAQ entry someone will point out, but shuffle de-duplicates the playlist, so you don't get repeats. There's a way to turn this off if you want in the config file.
#146829 - 05/03/2003 02:25 Re: play all songs [Re: matthew_k]
ricin
Loc: US: CA
Correct. See here.
Damn it, now I feel stupid, that's exactly what Tony already linked to. Guess I should actually *read* the rest of the thread and pay attention.
Edited by ricin (05/03/2003 02:28)
ricin
MkII/080000565
MkIIa/010101253
ricin.io
#146830 - 05/03/2003 08:18 Re: play all songs [Re: ricin]
Errrm - ah. Okay, that all makes sense. Did a quick FAQ check a while back and didn't spot that one.
Cheers ricin
Ror
