#148026 - 11/03/2003 16:08 Problem after drive upgrade
smu
Loc: Germany (Ruhrgebiet)
Hi.
I recently upgraded my empeg's HD to a nice 60GB disc. However: While the player seems to run fine, I took it inside for a few uploads and sync is _SLOW_ to say the least. I expected the fs checks to be much slower than with the previous disc, but there seems to be an additional problem, which I noticed on the log when connected by serial during a sync:
empeg:/empeg/bin# logout
Shell exit
Starting player
Using non-standard cache size 20 (adjustment 64)
! tags.cpp : 61:Failed to open tags (0xc0041002).
Restored terminal settings
No secondary hard disk
Abnormal player termination
Player received SIGINT, user interruption
Starting bash.
Shell exit
Starting player
Vcb: 0x4014d000
Adding Swap: 24060k swap-space (priority -2)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
hda: irq timeout: status=0xd0
ide0: reset: success
end_request: I/O error, dev 03:04 (hda), sector 2883864
hda: status timeout: status=0xd0
hda: drive not ready for command
end_request: I/O error, dev 03:04 (hda), sector 6815816
end_request: I/O error, dev 03:04 (hda), sector 6815824
end_request: I/O error, dev 03:06 (hda), sector 8
end_request: I/O error, dev 03:06 (hda), sector 16
This does not look normal to me, but what exactly might this mean? The sector on which the error occures is different on each occasion. But the pattern is always the same.
Any hint would be appreciated.
cu,
sven
#148027 - 11/03/2003 17:52 Re: Problem after drive upgrade [Re: smu]
My first guess would be either a bad drive (seems unlikely assuming it's new) or a bad IDE cable. Perhaps the crimp on the connector you're using now is bad. (Did you replace or add a new drive?) Did you let the stress test run? You could try it on both connectors and see if it's different between them.
#148028 - 11/03/2003 18:51 Re: Problem after drive upgrade [Re: wfaulk]
Another thought would be the dry solder connections. I would recommend (if you don't have much data on it yet) a rebuild and stress test.
