#149866 - 23/03/2003 09:51
Re: I see that...
[Re: Daria]
Huh? You've lost me...
- Trevor
#149868 - 23/03/2003 10:01
Re: I see that...
[Re: Daria]
Loc: Greenhills, Ohio
I turned green and I didn't even notice. It must be because I am envious of Mark's workshop (or rather the skill to use all of those tools).
I am trying to hang some shelves today and failing miserably at it, I hate plaster walls
Laura
MKI #017/90
whatever
#149870 - 23/03/2003 10:26
Re: I see that...
[Re: Daria]
Yeah I would but stud finders do not work on plaster walls, at least the one I have doesn't.
*surveys the 10 holes she has drilled in a row so far trying to locate a stud*
Sigh.
Laura
MKI #017/90
whatever
#149871 - 23/03/2003 10:31
Re: I see that...
[Re: Daria]
Well spotted, I hadn't noticed (probably because I never read my own posts).
#149874 - 23/03/2003 10:46
Re: I see that...
[Re: Laura]
If you have a fairly powerful magnet handy, run it slowly back and forth over the wall until you locate a nail- or screw-head. It works quite well, you can feel the drag as you pass anything magnetic.
#149875 - 23/03/2003 11:11
Re: I see that...
[Re: pca]
Or just strap on a pair of the X-ray goggles that Patrick is wearing in his current avatar picture...
#149876 - 23/03/2003 11:12
Re: I see that...
[Re: pca]
This girl has decided who the hell needs shelves anyway. After 2 hours I got the left half of one bracket up, seems the right side is off of the stud though. Grrrrrrr.......
Seems the studs are spaced 15" apart, I did find that out finally and have many holes to spackle.
Laura
MKI #017/90
whatever
#149877 - 23/03/2003 11:24
Re: I see that...
[Re: Laura]
*kicking myself*
Seems that the stud sensor does work on plaster walls once you have fresh batteries in it and know where a stud is to test it on.
I guess one is never too old to learn something new. Now to go off and hang 3 shelves in my work room.
Laura
MKI #017/90
whatever
#149878 - 23/03/2003 11:26
Re: I see that...
[Re: Laura]
#149879 - 23/03/2003 11:58
Re: I see that...
[Re: Daria]
Has decided to give up and is heading off to the hospital for stitches now. Don't ask.
Laura
MKI #017/90
whatever
#149881 - 23/03/2003 12:09
Re: I see that...
[Re: Laura]
Arrgh... I can empathise with strangely spaced studs. My house was built in 1860, apparently before they had invented standards.
When I recently tried to put a small shelf in my bathroom, I ended up cutting away a horizontal inch-wide strip of plaster and lathe until I located the 2 studs, and then fashioning a wooden cross brace to fix to the studs, sitting nearly flush with the wall. I then spackled over the top, and fixed the shelf into the brace. It was the only way I could find to put the shelf where I actually needed it.
#149882 - 23/03/2003 12:11
Re: I see that...
[Re: Laura]
#149885 - 23/03/2003 13:41
Re: I see that...
[Re: Laura]
Don't ask. But I always ask. It comes from getting too many stitches in such stupid ways that I'm instantly curious to know about other people's stitches. :P So.... what did you do?
#149886 - 23/03/2003 14:19
Re: I see that...
[Re: canuckInOR]
They ended up not putting in stitches and just used steri-strips but since I hit it so hard with the hammer that it split the skin they did take x-rays, nothing broken thankfully. I wish they had given me something for the throbbing pain though, aspirin just isn't cutting it.
Now to go clean the blood off of the wall.........
Laura
MKI #017/90
whatever
#149887 - 23/03/2003 14:50
Re: I see that...
[Re: Laura]
They'll actually be 15.25" (average) apart, except near doorways and/or windows.
#149888 - 23/03/2003 14:53
Re: I see that...
[Re: Laura]
Steri-strips are a modern miracle! I have several huge packets full of various sizes of them here, and more in the first aid kit that goes climbing with me.
For those who have not yet discovered them, DO SO! They act like sticky stitches, placed directly over the wound in a such a manner as to pull the two sides together and keep them that way, and clean. Best for clean cuts/slices, lousy for scrapes. Healing time is vastly improved, since the skin doesn't have to waste effort developing a scab to do the same job.
#149889 - 23/03/2003 14:58
Re: I see that...
But one doesn't get any sympathy for steri-strips not that I probably would have anyway with stitches. I'll pick up some more of them tomorrow at work, I'm sure these won't last for 10 days.
Laura
MKI #017/90
whatever
#149890 - 23/03/2003 15:51
Re: I see that...
You want to try staples for that  . When I cut my head open in France (snowboarding) earlier in the year, I thought that I'd misheard or mistranslated what the French doctor was telling me.
Turns out, I hadn't. She put two staples in my scalp.
#149891 - 23/03/2003 16:17
Re: I see that...
[Re: Roger]
Oh, staples. You have my belated sympathy
Laura
MKI #017/90
whatever
#149892 - 23/03/2003 16:33
Re: I see that...
[Re: Laura]
Sorry to hear about the masochistic (sp?) incident. But jeez that was funny.
depending on the size of the shelves and the load (books weigh a lot), you could use a metal spring toggle to hold them.
Murray
Is it the 'N', or the 'Zero'?
#149893 - 23/03/2003 17:14
Re: I see that...
[Re: Roger]
One of my friends in grade school (like back in 1986 or something) fell off the slide onto the tarmac/concrete (none of this wussy rubber stuff they got going on now). He ended up having like 10 staples in his head or something.
It was amazing how much enjoyment he got out of showing them to the girls and grossing them out...
#149894 - 23/03/2003 18:39
Re: I see that...
[Re: Laura]
Loc: New Orleans, LA
I assume steri-strips are akin to butterfly bandages? If so they do work well but have a tendency to scar. At least they did on me. Right in the middle of my forehead, too. Oh well... I usually carry superglue and Nu Skin whenever I go camping/hiking/doing anything dangerous. I love Nu Skin particularly, as I use it to prevent blisters in places I know will normally get blisters. Great for bowling.
