#152435 - 01/04/2003 16:20 TTSClock, Hijack - HELP!
KungFuCow
Im trying to get TTSClock running again under 2.0. Does TTSClock still require preinit or has the Hijack ;ExecOnce command taken it's place or will the Execonce command not execute scripts?
I have no problem reinstalling preinit if need be, I just wanted to see if there was a work around using Hijack instead. Any help would be greatly appreciated.
#152436 - 01/04/2003 18:44 Re: TTSClock, Hijack - HELP! [Re: KungFuCow]
My first thought is that it's ;@EXEC_ONCE
Did you ``spell'' it right in your config.ini?
#152437 - 01/04/2003 19:38 Re: TTSClock, Hijack - HELP! [Re: KungFuCow]
genixia
My first thought is that anything on /programs0 or /programs1 won't work immediately after an upgrade - the mountpoints will no longer exist, nor the entries in /etc/fstab that get them mounted.
When I work out how to get the 2.0 software on my player I'll look into a simple restore script. (No linux upgrade software, and the new installshield wont install Emplode on my old Win95 laptop.)
#152438 - 01/04/2003 20:14 Re: TTSClock, Hijack - HELP! [Re: genixia]
KungFuCow
The only thing deleted by the upgrade for TTSClock was the script itself and I reuploaded that and chmod'ed it. Ive tried calling it from Hijack using ;@Execonce and it doesn't find it. Even logged in with a terminal and watching bootup, I dont see where it's even going looking for it.
Oh yea, preinit was also deleted but Im trying not to use that.
TTSClock gets uploaded to /drive0/var, BTW.
#152439 - 01/04/2003 20:40 Re: TTSClock, Hijack - HELP! [Re: KungFuCow]
DomoKun
Loc: Pennsylvania
I'll try to make an updated version of the TTSClock script over the weekend to make it more Hijack friendly. I'll also add a command line option to specify different timezones so you're not forced to use Universal time if you don't want to.
