#15425 - 25/08/2000 09:02 AUX bug
dionysus
Loc: San Francisco, CA
OK - haven't seen this reported, so here it goes:
If the empeg is turned on in AUX mode, switching to the equalizer (without the remote - I haven't had the chance to test this with the remote..) silences the output. The only way to fix it has been to pull out empeg and put it back in:(
-mark
...proud to have owned one of the first Mark I units
#15426 - 25/08/2000 09:29 Re: AUX bug [Re: dionysus]
Actually, Doug Burnside beat you by about 8 hours. We'd actually discussed it in private e-mail as much as a day earlier than that. So nyah nyah.
________________
Timestamp Police
#15427 - 25/08/2000 14:40 Re: AUX bug [Re: tfabris]
dionysus
ok; but for the record I found that bug while driving to keywest on Monday night:)
-mark
#15428 - 25/08/2000 21:04 Re: AUX bug [Re: dionysus]
Actually, Di, I found an easier way to get the music back. Exit the equalizer (you have to save the settings, even if you didn't really change anything) and hit the top button twice --the first press puts it into pause mode, the second press takes it out of pause and the music resumes.
Apparently there is a workaround, too, I haven't tried this but someone at empeg sent me an email... If you do all your equalizer changes using the remote instead of the front panel buttons, the audio doesn't stop.
