I don't normally follow the bugs forum so I apologize if this is redundant. I am getting a player crash followed by a restart almost everytime I try to quit to the shell using 'q' from a terminal. This seems to happen about 9 times out of 10. This is on a fresh 2.0final install with hijack330, hijack330+ext3 or the stock empeg kernel. The empeg is a dual drive mk2a. Using control-c instead of 'q' seems to quit without the crash. Crash dump is below, any thoughts?
-Mike
player(23): memory violation at pc=0x020dd5d8, lr=0x00000000 (bad address=0x344)
pc : [<020dd5d8>] lr : [<00000000>]
sp : bffffc6c ip : bffffc8c fp : bffffc88
r10: 0214d594 r9 : 02151674 r8 : 02151684
r7 : 02156e70 r6 : 0214ca08 r5 : 02156668 r4 : 00000808
r3 : 3447a0a0 r2 : 00000809 r1 : 32323230 r0 : 0214ca08
Flags: nzcv IRQs on FIQs on Mode USER_32 Segment user
Control: C0F7517D Table: C0F7517D DAC: 00000015
Function entered at [<020dd4d4>] from [<020dd4a4>]
r7 = 0215165C r6 = 021515A8 r5 = 02156668 r4 = 0214CA08
Function entered at [<020dd3fc>] from [<020c4758>]
r5 = 00000003 r4 = 02156618
Function entered at [<020c46d4>] from [<02081438>]
r10 = 02151650 r9 = 02151674 r8 = 02151684 r7 = 0215165C
r6 = 021515A8 r5 = 00000003 r4 = 02156618
Function entered at [<02081410>] from [<02063e24>]
r5 = 02151668 r4 = 00000055
Function entered at [<02063c98>] from [<020adb90>]
r10 = BFFFFEE4 r9 = 00000001 r8 = 0214D808 r7 = BFFFFEE8
r6 = 00000086 r5 = 00000002 r4 = BFFFFE84
Function entered at [<020adb50>] from [<020768d4>]
r4 = BFFFFE84
Function entered at [<020768b4>] from [<0202f6f4>]
r5 = 00000002 r4 = BFFFFDF4
Function entered at [<0202f684>] from [<0203168c>]
r5 = 00000000 r4 = BFFFFDF4
Function entered at [<02031464>] from [<02031794>]
r10 = 02031730 r9 = 00000000 r8 = 02112060 r7 = 00000000
r6 = 020000C0 r5 = 00000001 r4 = BFFFFF64
Function entered at [<02031730>] from [<020c8ea4>]
r5 = BFFFFF64 r4 = 00000001
Function entered at [<020c8dc8>] from [<02000104>]
r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000
r5 = 00000000 r4 = 00000000
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
