#156354 - 21/04/2003 07:22 Easier way to solder the resistor pack?
lopan
Loc: Manassas VA
I found this today while looking for power supplies.... Would this make soldering that pesky resistor pack for the button hack easier?
Brett 60Gb MK2a with Led's
#156355 - 21/04/2003 09:36 Re: Easier way to solder the resistor pack? [Re: lopan]
mtempsch
If you used tin in paste form, maybe. Then you could essentialy pick it up and place it, hold for a second or two and then let go. I found the problem not being the two sides, but rather the very small distance between the contact surfaces on the side where you have to keep the connectors separate, and the tins willingness to form bridges. That's generally controllable with good fluss.
#156356 - 21/04/2003 14:43 Re: Easier way to solder the resistor pack? [Re: lopan]
It's not too bad with just a nice soldering iron (0.01" tip), and lots of flux.
