#157466 - 28/04/2003 00:01 How does one convert CSV to M3U?
jamville
Loc: South Texas
With Emplode 2.0 you can export to a csv. And/or you can import from a m3u.
If you want to use one play list on two or more Mk2a's, how do you go about it?
Thank you,
Joe Mumme
#157467 - 28/04/2003 00:36 Re: How does one convert CSV to M3U? [Re: jamville]
simspos
Loc: Dudley, UK
The m3u file is just a text file (I think!), so you could just grap the appropriate listing from the csv file and do a little "manual manipulation" (examine the structure of a working m3u file first and you shouldn't go far wrong)
Tedious but should work as long a you only want to do the odd playlist
Cheers, Sim
#157468 - 28/04/2003 06:15 Re: How does one convert CSV to M3U? [Re: simspos]
It ain't that easy -- the CSV file lists the contents of playlists by FID. If you wanted to convert this into an M3U (which is a list of files), you'd have to convert each of those FIDs back to the original filename. This isn't going to be easy -- we don't keep the original filenames around.
Frankly, you're better off either not bothering, or keeping the two empegs completely in sync. See this or this.
#157469 - 28/04/2003 06:47 Re: How does one convert CSV to M3U? [Re: Roger]
simspos
Loc: Dudley, UK
Sheesh, I knew my logic would be flawed somewhere, completely forgot the filenames are lost on import to the empeg.
Like Roger said, it ain't easy.
Cheers, Sim
#157470 - 28/04/2003 10:39 Re: How does one convert CSV to M3U? [Re: jamville]
Yup, apples and oranges.
To restate what's been said: The CSV from Emplode doesn't contain the same data as an M3U file would need.
CSV: The internal track database of the car player, which knows nothing about your PC.
M3U: A list of file names on your PC's hard drive, which knows nothing about the tracks on your player.
However, you can download all the songs off your player onto the PC, then you can use a DOS batch file with a carefully formatted DIR command to create one big M3U of all the subdirectories.
#157471 - 28/04/2003 14:17 Re: How does one convert CSV to M3U? [Re: tfabris]
SumnerHayes
Unix-style file utilities are a godsend for this sort of thing--you can get the Cygwin stuff (Unix utils for Windows) for free from http://www.cygwin.com/ .
Then it's just:
find . -name '*.mp3' -type f | sort > allfiles.m3u
and you'll have an m3u of all the mp3 files under the current directory. You can get a lot more sophisticated than this without needing to learn much more than the options to find and a bash for loop.
Sumner
#157472 - 28/04/2003 23:26 Re: How does one convert CSV to M3U? [Re: SumnerHayes]
jamville
Loc: South Texas
Thanks for all your input guys.
Joe Mumme
