#157701 - 28/04/2003 17:45 I need Help! Disconnected wire from the sled!
Banacek
Ok, I was installing my empeg into the new car, and two of the wires came loose from the back of the sled. I read the FAQ, got the connector pins out, but one of the connector pins broke. Any ideas where I get can get other one? Thanks in advance, I'm losing my mind
#157702 - 28/04/2003 23:20 Re: I need Help! Disconnected wire from the sled! [Re: Banacek]
jarob10
Loc: Stockport, UK
I have 1 or 2 spare pins if you are struggling
#157703 - 29/04/2003 08:37 Re: I need Help! Disconnected wire from the sled! [Re: Banacek]
maczrool
Loc: Louisiana, USA
If you wish to buy some, the Digikey part number is H10087-ND
Stu
#157704 - 29/04/2003 14:21 Re: I need Help! Disconnected wire from the sled! [Re: maczrool]
Banacek
Thanks, I gonna have to pick some up. I'd probably be better picking up like 10, just in case things go wrong. I'm so glad. Ive been a little upset since my empeg broke
#157705 - 29/04/2003 15:01 Re: I need Help! Disconnected wire from the sled! [Re: Banacek]
maczrool
Loc: Louisiana, USA
Just be sure to check the picture they have to be sure it is what you need. It looks like the sled half to me, which I believe is what you said you needed.
Stu
