#158203 - 30/04/2003 11:55 No hard disk found, Contact support
misaochankun
Loc: South Florida, USA
This morning, I was greeted to this as I put in the empeg.
I can hear the hard drive spinning up and such, and I hear nothing loose inside. Below is the serial port output.
In the past I had to replace the hard drive cable due to that batch of bad cables, it has been fine otherwise:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 9, serial number 10101910)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005400).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:7
6
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
S/N:010101910
#158204 - 30/04/2003 11:57 Re: No hard disk found, Contact support [Re: misaochankun]
Greetings!
Probably one of the most Frequently Asked Questions on the board...
#158205 - 30/04/2003 11:59 Re: No hard disk found, Contact support [Re: pgrzelak]
misaochankun
Yes I know, Im not a n00b
I'm hoping the diag output was more informative.
I might also add that I upgraded to 2.00 official a couple weeks ago, so I hope that didn't kill it.
S/N:010101910
#158206 - 30/04/2003 11:59 Re: No hard disk found, Contact support [Re: pgrzelak]
Yup. And it doesn't seem to see a hard drive at all. I'd guess that that's likely to mean that the cable has come loose rather than a bad drive. But I could well be wrong.
#158207 - 30/04/2003 12:04 Re: No hard disk found, Contact support [Re: wfaulk]
Greetings!
Well, the faq has some good troubleshooting steps, and rather than try to reproduce it... I agree - it does not seem like a bad drive, unless the drive completely failed. It is not recognizing or responding at all. I suspect the cable or connection most. If you can open the unit, that would be the best check.
#158208 - 30/04/2003 12:36 Re: No hard disk found, Contact support [Re: pgrzelak]
csf
Loc: Charlotte, NC
The drive cable has come out of the drive several times (2-3) in my unit. It always says "no drive found".
I need to find a hot glue gun to borrow.
10+40 Gig Mk2a... with Tuner. S/N 040103784 || 2001 Jeep TJ, 60th Anniversary Edition
#158209 - 02/05/2003 16:17 Re: No hard disk found, Contact support [Re: wfaulk]
I think someone must be laughing somewhere... I had the same issue with my player this afternoon. Ugh. I don't have the time to be opening and fixing drive cables again.
Last night I'm reading about the dicontinuation of Car support, spending more time on the BBS than I have as of late (had a night to myself) and today... On the way to work a hang starting a track - it had been playing about 5 minutes and then just stopped at exactly 0:00 of the next track. Could not seek nor skip, but could enter the menu (player app was not hung). Entered Hijack, rebooted and everytihng was fine.
Get into my car this afternoon at about 4pm and I get the No DIsk message - the trusty message I first saw on my player back in November 2001. Blech. Reboot and all's good. Watched X-Men 2, started the car again and player stops while "Loading Playlists..." Reboot once more and all's fine for the drive home.
Now to find the time to crack it open and check what's up... Fun fun fun during what was already lining up to be a busy weekend.
