#162253 - 20/05/2003 10:52 DIsplay Garbled...
snoopstah
Loc: Squamish, BC
Here's a puzzler for you guys...
I have the symptoms of a garbled display (as discussed in the FAQ). In the FAQ, it states it is likely to be a fuse that has blown, and that this can blow without provocation (which, as I haven't touched the player in months, is fair enough).
The only odd part about the whole thing is... if I shake the player it works again.
Obviously, fuses don't start working again when kinetic energy is imparted upon them, so it sounds like a loose connection. As the chances of a loose connection on a surface-mount component such as one of the fuses is ludicrously small (although I'm not ruling it out), what other areas should I be checking?
#162254 - 20/05/2003 10:56 Re: DIsplay Garbled... [Re: snoopstah]
I dunno how those SMT fuses are made. Maybe they do work that way?
Anyway, one other thing that it could be is the display cable, as described in the next FAQ entry right after the one you linked. If it turns out to be that, let me know so that I can update the entry you linked.
