#162262 - 20/05/2003 15:04 LogoEdit Error
NicolasW
Loc: USA
Tony -
I'm trying to upgrade my HiJack on my Empeg and I am getting an "Error status in readbyte 16" error.
Since the last time I have installed HiJack, I have installed Microsoft Activesync (program used to sync Pocket PC with computer) and am not sure if that is causing it.
Also, my logoedit files are stored on a different computer (accessing them over the network)....do the files need to be installed locally?
Thanks much,
Wes
#162263 - 20/05/2003 15:06 Re: LogoEdit Error [Re: NicolasW]
Greetings!
It is likely that ActiveSync is your problem, especially if they are fighting for the same serial port...
#162264 - 20/05/2003 15:08 Re: LogoEdit Error [Re: NicolasW]
That is possible if ActiveSync uses the serial port. Please try disabling the ActiveSync software.
I do not know. Please try copying all files (all logoedit files as well as the kernel you're trying to install) to the local computer and see if that works.
#162265 - 20/05/2003 15:27 Re: LogoEdit Error [Re: tfabris]
NicolasW
Loc: USA
Drat....
I uninstalled ActiveSync and copied all files (Logo edit and HiJack kernel file) to the local machine I still got the same error.....and then, I replaced the cable with a new serial cable (spare Empeg box) and it worked!!
Must have killed the cable somehow.
Wes
#162266 - 20/05/2003 15:27 Re: LogoEdit Error [Re: NicolasW]
AndrewT
Loc: Oxford, UK
If your pocket PC doesn't use the PC's serial connection you can tell ActiveSync not to use it. It's quite simple to do but I can't tell you how from memory. Let me know if you want more info. on finding where to disable it.
