I think my drive died. Here's some background: I was running 2.00 released image with hijack 330. I would occasionally get 'W' messages in the upper right corner when the drive was being accessed. Just last week I had a strange occurence where a fragment of a different song would be inserted into the current song.
Today, I added some old Monty Python wav's I had laying around, deleted some tracks, upgraded hijack to 335, then rebooted. When it came up, I no longer had any playlists. So, I did some searches here and found out how to rebuild the database manually. Also, sync's were failing with odd errors using jEmplode. I installed the developer image and got to the bash prompt. It looks like /dev/hda4 is non existant. Here's a fragment of the boot screen:
EXT2-fs error (device ide0(3,4)): ext2_check_descriptors: Block bitmap for group
128 not in group (block 0)!
Remounting filesystem read-only
EXT2-fs: group descriptors corrupted !
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Am I hosed?
Thanks,
Kermit
