#163899 - 02/06/2003 22:27 Sync Problem
mwest
Loc: Ada, Oklahoma
My empeg suddenly won't sync.... I've read the faq and a lot of the threads that seem similar to my problem are way over my head usally involving linux.
I have a MKIIa with a 80 gb hard drive. It seems to work fine other than the sync problem. When I try to sync, emplode finds my player and begins to check media. It takes a long time to begin to show any progress. When it does it moves pretty quickly. Emplode then says that its remounting the drives... but while it does this the player reboots and then Emplode dies. The error reads:
EMPLODE caused an invalid page fault in
module EMPLODE.EXE at 017f:0045af70.
Registers:
EAX=00000000 CS=017f EIP=0045af70 EFLGS=00010246
EBX=00000000 SS=0187 ESP=0074ed8c EBP=00000000
ECX=00000000 DS=0187 ESI=008787f0 FS=62f7
EDX=00878700 ES=0187 EDI=008783c0 GS=0000
Bytes at CS:EIP:
8b 41 08 85 c0 75 03 88 41 46 40 89 41 08 c3 90
Stack dump:
0045e4aa 008783c0 008783c0 00000000 008787f0 0074edd0 004aa57b 00000000 00443567 00000000 00000000 008783c0 00878860 00000000 00000001 008783c0
I've opened the player and tried the connections and switched the ide cable end from first to second place with the same results.
Any help?
-Michael West
#163900 - 02/06/2003 22:34 Re: Sync Problem [Re: mwest]
mwest
Loc: Ada, Oklahoma
The boot log looks like this...
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320 (root@cushman) (gcc version 2
.95.3 20010315 (release)) #1 Mon Mar 10 06:11:37 EST 2003
empeg-car player (hardware revision 9, serial number 10101450)
Command line: mem=16m
Memory: 15024k/16M available (972k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N080ATMR04-0, ATA DISK drive
hda: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:a
a
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg-preinit starting...
mount: /programs0: No such file or directory
Using /etc/preinit.d as startup script directory
empeg-preinit complete
empeg init 0.8
Mounting proc
No secondary hard disk
Starting player
hijack_exec("/bin/bash -c "/usr/local/bin/start_empire 10 &""), rc=0 (okay)
khttpd: listening on port 80
kftpd: listening on port 21
start_empire: sleeping for 10 seconds...
! tags.cpp : 61:Failed to open tags (0xc0041002).
start_empire: Starting Empire...
IrDA: Registered device irda0
irlap_driver_rcv(), Unknown frame ef received!
Vcb: 0x4086d000
-Michael West
#163901 - 03/06/2003 03:41 Re: Sync Problem [Re: mwest]
Ow.
Have you tried doing a disk check (FSCK) by hand? That might fix the problem.
Hmmm... In all my time playing with the 80s, I have never had the player do a disk check during sync. Most of the music I have is already on the player, and I am in shell often enough that I do the checks there. I never tested this bit... I wonder if the emplode disk check itself is sick... Hmm... Time to test...
#163902 - 03/06/2003 04:12 Re: Sync Problem [Re: pgrzelak]
Greetings!
Interesting. I am doing some testing now...
Running Windows 2000 Server (I am in the office), I connected to the player with hyperterminal. I verified that my disks were in good shape, not needing a sync. I then did a "rw" command and pulled the power. I plugged it back in, and verified that the root partition needed an fsck.
I went into emplode, turned on logging, connected to the player over fixed IP ethernet. I made a small change to the configuration of the player and performed a sync.
Interestingly, the dirty partition check / media check only happens for dirty music partitions, not for the root partition!!! I think this is a bug!
So, after the sync completed, I exited emplode, deleted the log file, hyperterminal connected in. The root partition was still dirty. I did an "rw" and an "rwm", did a "sync" (I like my data, thank you...) and pulled the power. Went into emplode, with logging on, made a configuration change and did a sync.
This time, it is checking the hard drives with a full fsck. More to follow as the check happens - from command line experience, it takes about 50 minutes per drive. I am capturing a log, so if something does blow up, I can post / send to someone.
Edit: Actually, sitting here watching the indicator not move across the screen, I remember that I did do a full sync with disk check on the 80s before. That was right after the rebuild on the primary unit. But this is still a good test anyway. You may want to try getting a log of your sync - it might help troubleshoot, but try the manual fsck also.
Edited by pgrzelak (03/06/2003 04:18)
#163903 - 03/06/2003 07:25 Re: Sync Problem [Re: pgrzelak]
Nope. Clean resync. You may want to try doing it manually, just to check.
#163904 - 03/06/2003 09:09 Re: Sync Problem [Re: pgrzelak]
mwest
Loc: Ada, Oklahoma
OK.. I can't get to riocar.org for some reason... Can someone give me a quick manual fsck tutorial?
-Michael West
#163905 - 03/06/2003 09:42 Re: Sync Problem [Re: mwest]
Greetings!
The FAQ is back up, but here are the basic commands. If you have a single disk player, do not uncomment the commands for the second drive. If you run into any trouble, let me know.
ro
umount /dev/hda4
#umount /dev/hdc4
swapon /swapfile
fsck -fay /
fsck -fay /dev/hda4
#fsck -fay /dev/hdc4
swapoff /swapfile
sync
(reboot at this point)
#163906 - 03/06/2003 10:00 Re: Sync Problem [Re: mwest]
Mwest, did you add any third-party programs to the player? Do they run in AC mode, or have they been set to @DC? That could have been the root cause of the problem.
#163907 - 03/06/2003 10:46 Re: Sync Problem [Re: tfabris]
mwest
Loc: Ada, Oklahoma
Not recently...
-Michael West
#163908 - 03/06/2003 11:21 Re: Sync Problem [Re: mwest]
mwest
Loc: Ada, Oklahoma
Ok I did what Paul suggested and I'm getting the same problem... Here's what I did and the boot logo for right after I did it.
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# unmount /dev/hda4
bash: unmount: command not found
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# #umount /dev/hdc4
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1514/4096 files (0.5% non-contiguous), 9457/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
hda4 is mounted.
Duplicate blocks found... invoking duplicate block passes.
Pass 1B: Rescan for duplicate/bad blocks
Duplicate/bad block(s) in inode 5286: 11137102 11137103 11137104 11137105 111371
06 11137107 11137108 11137109 11137110 11137111 11137112 11137113 11137114
Duplicate/bad block(s) in inode 5288: 11137102
Duplicate/bad block(s) in inode 5290: 11137103
Duplicate/bad block(s) in inode 5292: 11137104
Duplicate/bad block(s) in inode 5294: 11137105
Duplicate/bad block(s) in inode 5296: 11137106
Duplicate/bad block(s) in inode 5298: 11137107
Duplicate/bad block(s) in inode 5300: 11137108
Duplicate/bad block(s) in inode 5301: 11137109 11137110 11137111 11137112 111371
13 11137114
Pass 1C: Scan directories for inodes with dup blocks.
Pass 1D: Reconciling duplicate blocks
no room for private writable mapping
error: -12
fsck.ext2: Memory allocation failed while retrying to read bitmaps for /dev/hda4
empeg:/empeg/bin# #fsck -fay /dev/hdc4
empeg:/empeg/bin# swapoff/swapfile
bash: swapoff/swapfile: No such file or directory
empeg:/empeg/bin# swapoff /swapfile
empeg:/empeg/bin# sync
empeg:/empeg/bin#
e000 v1.04
Copying kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg state support initialised 0089/88c1 (save to d0005b00).
a
Partition check:
Mounting proc
Starting player
Vcb: 0x4086d000
serial_notify_thread.cpp: 116:@@ N167
serial_notify_thread.cpp: 117:@@ F0x45a0
serial_notify_thread.cpp: 118:@@ TLinger
serial_notify_thread.cpp: 119:@@ ACranberries
serial_notify_thread.cpp: 120:@@ GRock
serial_notify_thread.cpp: 180:@@ #45a0 0:00:01
-Michael West
#163909 - 03/06/2003 11:24 Re: Sync Problem [Re: mwest]
Um, this is interesting. From the report, you did the swapon /swapfile. It took it, and gave the report out. But it looks almost like there was so much that needed to be done, that you ran out of memory, even with swap on.
You may want to try that command set again, see if it correct the first set of errors (the ones it already found), and moves on from there.
#163910 - 03/06/2003 11:30 Re: Sync Problem [Re: mwest]
Odd. It would appear that your fsck ran out of memory even after you added some virtual memory (using the swapon command). It would appear you have an 80GB drive, right?
That's distressing. It would appear that the big partition plus the limited memory is causing a problem. Do you have a Mk2 or Mk2a? There's a memory difference between them.
Solution: Add more memory, virtual or not. You have only one drive, right? If you have two, you could add its swap space as well. If you do have only one, then I guess you need to fsck the root partition (you've already done this), remount it rw, create a big file, and then use it as swap space as well. I can't give you specific instructions, though, as I don't have anything to test on right now.
Something like this ought to work, though:
rw
dd if=/dev/zero of=/swapfile2 bs=1048576 count=16
swapon /swapfile2
swapon /swapfile
fsck -fay /dev/hda4
swapoff /swapfile
swapoff /swapfile2
rm /swapfile2
ro
<reboot>
#163911 - 03/06/2003 14:23 Re: Sync Problem [Re: pgrzelak]
mwest
Loc: Ada, Oklahoma
trying it now...
-Michael West
#163912 - 03/06/2003 14:54 Re: Sync Problem [Re: wfaulk]
mwest
Loc: Ada, Oklahoma
Ok I've done something wrong... when I started to do your suggestion I got this....
Starting bash.
empeg:/empeg/bin# rw
empeg:/empeg/bin#
empeg:/empeg/bin#
empeg:/empeg/bin# dd if=/dev/zero of=/swapfile2 bs=1048576 count=16
dd: /swapfile2: No space left on device
7+0 records in
6+0 records out
empeg:/empeg/bin# swapon /swapfile2
Unable to find swap-space signature
swapon: /swapfile2: Invalid argument
empeg:/empeg/bin# swapon/swapfile2
bash: swapon/swapfile2: No such file or directory
empeg:/empeg/bin#
-Michael West
#163913 - 03/06/2003 15:12 Re: Sync Problem [Re: mwest]
Okay. First, 16MB seems to be more space than the root partition has. You should be okay, though, as it got 7MB written.
Second, I forgot that Linux has some sort of magic that makes a swap file swappish. Try running ``mkswap /swapfile2'', and then continue from ``swapon /swapfile2''.
#163914 - 03/06/2003 16:23 Re: Sync Problem [Re: wfaulk]
Any luck with the retry?
#163915 - 05/06/2003 13:30 Re: Sync Problem [Re: pgrzelak]
mwest
Loc: Ada, Oklahoma
Worked like a charm guys... thanks a lot. Sorry for taking so long to answer... Trigonometry keeps sucking up my free time.
-Michael West
#163916 - 05/06/2003 13:31 Re: Sync Problem [Re: mwest]
mwest
Loc: Ada, Oklahoma
By the way... what did I just do?
-Michael West
#163917 - 05/06/2003 13:34 Re: Sync Problem [Re: mwest]
Greetings!
Normally, the "swapon /swapfile" command takes the default swap partition (I do not remember the size) and makes it available. This way, the kernel has the physical memory plus the swap to play with, taking your 16MB up to 16+x. What this did was to create another "swap" space, using space from the root partition, and adding it as well to give you 16+x+y MB of RAM - enough to get you through your sync.
Note - I have not seen the duplicate block problem before, so you will not need to do this for every sync going forward. I think this was more a special case, based on the type of error that fsck found.
#163918 - 06/06/2003 06:59 Re: Sync Problem [Re: pgrzelak]
mwest
Loc: Ada, Oklahoma
Cool, thanks for the help guys!
-Michael West
