#165983 - 15/06/2003 23:37
Original art assets used in XML interface?
I'm writing another application for the empeg that makes use of pictures of the remote control and of the empeg face. For the moment, I've lifted the art from CharcoalGray99's XML interface for this purpose. I would like to continue using this art because it looks really good, but I want to make sure I obtain the permission of the original creators before making this app public.
The image of the empeg is the one that's scaled so that the screen matches up with a 128x32 VFD screen capture. I believe it was originally lifted off of the Rio web site where animated GIF examples of the empeg visuals were being shown.
I don't know for sure where the image of the remote came from. I know it is also used in another HTML/Javascript remote control implementation similar to CharcoalGray99's web interface, but I don't know which is the chicken and which the egg, so to speak.
So who were the original creators of these images?
#165984 - 23/06/2003 21:35
Re: Original art assets used in XML interface?
*BUMP*
Nobody?
I've realized that the face image is a resized version of the original pre-molding CAD renders when they were developing the Mk2 fascia. But I don't know where the Rio Remote image came from.
I'm really close to release on this software... And no one's even expressed a curiosity about it.
#165985 - 23/06/2003 21:37
I figured you wouldn't tell us what it is until it's done anyway
#165986 - 23/06/2003 21:40
[Re: msaeger]
Well, I'd tell you, but then I'd have to kill you. Either that or let you beta test it.
#165987 - 24/06/2003 01:40
Depending on the quality of the software, these two might turn out to be equivalent  .
#165988 - 24/06/2003 10:30
[Re: Roger]
Depending on the quality of the software, these two might turn out to be equivalent. Aw, hell, I'll just let you guys be the judge of that.
165516-empegface.zip (46 downloads)
#165989 - 24/06/2003 10:39
Loc: San Francisco, CA
Tony,
Bravo! This is fantastic! Exactly what I needed!
BTW, I'm running under XP and works like a champ.
- Jon
#165990 - 24/06/2003 10:47
[Re: jbauer]
Thanks, glad you like it!
Looking at the program, it seems like such a simple thing. But you wouldn't believe what a pain it was to code. Mostly because of the UI design choices I made. For instance, getting the rounded corners on the windows is like pulling teeth. I could have drawn region windows specifying point-to-point coordinates, but that would have been a pain. I finally found some example code on the 'net which created a region window from the form's bitmap and used that. (Note how you can see daylight through the gap by the handle hinges; that was my primary goal.  )
And then there was trying to deal with all of the permutations of long and short and double clicks, and drags, in such a way that it "felt right" to use. Sometimes it's hard to keep all of the event chains straight in your head.
I've just discovered another bug in the program I'll have to fix eventually... but I'll leave it up to you guys to find it.
#165991 - 24/06/2003 10:58
Cool. Works great here. One feature request and one bug report.
Is it possible to make it yield between refreshes though? It uses 100% CPU whenever I run it and on my laptop all of the fans suddenly kick in.
It's actually just a cosmetic bug but sometimes when I'm dragging the empeg or remote around the image jitters.
#165992 - 24/06/2003 11:00
I've just discovered another bug in the program I'll have to fix eventually... but I'll leave it up to you guys to find it. Hitting the buttons without your empeg present on the network crashes 'Face'
Do I win?
EDIT: Seems to crash without hitting buttons after a while of being open without an empeg to talk to. I wish I could check it out. It looks pretty dope.
Edited by robricc (24/06/2003 11:03)
#165993 - 24/06/2003 11:02
Another feature request: Can you add an option for the remote to be "always on top"?
Can you add that feature to my girlfriend as well???
- Jon
#165994 - 24/06/2003 11:03
[Re: tman]
Is it possible to make it yield between refreshes though? It uses 100% CPU whenever I run it and on my laptop all of the fans suddenly kick in. It does yield between refreshes. This is talked about in the readme file. Check what it has to say there, first.
sometimes when I'm dragging the empeg or remote around the image jitters. Yeah, I can't really do anything about that, it's the video driver. The same thing would happen on other programs if you activated the "show window contents while dragging" feature of Windows.
#165995 - 24/06/2003 11:03
[Re: jbauer]
Could be annoying if you're trying to use the computer or watching TV though...
#165996 - 24/06/2003 11:05
[Re: robricc]
Hitting the buttons without your empeg present on the network crashes 'Face' Odd, it doesn't do that on my systems. I specifically tested that feature. Does it give you a specific error message when you do that?
#165997 - 24/06/2003 11:07
Doesn't crash here without any empeg.
#165998 - 24/06/2003 11:07
[Re: jbauer]
Another feature request: Can you add an option for the remote to be "always on top"? I had considered this, but I thought it would get really annoying after a while, since the window is so large.
#165999 - 24/06/2003 11:11
I actually read the README just before you replied to me. I'll read it first next time
Yeah. It jitters quite a lot even though I'm not moving the mouse. As I said, it's just a cosmetic thing anyway.
#166000 - 24/06/2003 11:13
So large? On my screen, the remote is pretty small...
I'm at 1280 x 1024... plus, at home, I use dual monitors and want to put it in the upper right corner of my "utilities" display always...
- Jon
#166001 - 24/06/2003 11:20
[Re: tman]
It jitters quite a lot even though I'm not moving the mouse. I thought you meant that it sometimes left graphics blitter behind when you drag it across another window.
It shouldn't jitter at at all when you hold the mouse still, it doesn't do that on any of my systems. The only way that should happen is if the mouse itself is sending jittery data to the application (lots of one-pixel mousemove commands even when you're not moving the mouse).
#166002 - 24/06/2003 11:22
[Re: jbauer]
plus, at home, I use dual monitors and want to put it in the upper right corner of my "utilities" display always... I don't have dual monitors to test against, I'm curious to see if it correctly remembers its screen position (after exiting and restarting) on a second monitor. I'm guessing it won't. I'd be curious how to code for that instance, since I don't have a way of testing it.
#166003 - 24/06/2003 11:24
I'll test it when I get home tonight. So how tough is it to add that "always on top" feature?
- Jon
#166004 - 24/06/2003 11:25
The cursor is not moving at all and it doesn't happen in anything else. It's not important anyway and it's probably something to do with VB itself.
#166005 - 24/06/2003 11:27
[Re: jbauer]
I'm sure there's not much that can be done about it, but even with the refresh at 1000ms, it's taking up 97-100% CPU time on a dual 2.4 GHZ Xeon machine. =o
oh, and that is pimp!! very clean Tony. Nice work.
#166006 - 24/06/2003 11:30
I swear it crashed twice. Face was getting 'Not Responding' but ImageGrabber would continue to run after killing 'Face".
No error message.
I will try and break it again. I'm running XP Pro by the way.
#166007 - 24/06/2003 11:44
[Re: loren]
I'm sure there's not much that can be done about it, but even with the refresh at 1000ms, it's taking up 97-100% CPU time on a dual 2.4 GHZ Xeon machine. Right, all it's doing is sitting in a loop with a bunch of VB "doEvents" commands waiting for the other app to tell it what to do.
Y'all are putting too much stock in what the Task Manager is telling you. The only reason it's saying it's consuming 100 percent CPU is because it's the only app that's doing anything. As soon as you do something else on the PC, it'll automatically drop to lower than whatever the other app is doing. As soon as that other app goes idle, it'll start back into its loop again.
I agree, I know it can be coded more efficiently. It's on my to do list.
oh, and that is pimp!! very clean Tony. Nice work. Thanks!
#166008 - 24/06/2003 11:46
[Re: tman]
The cursor is not moving at all and it doesn't happen in anything else. That's odd. It shouldn't do that. I haven't seen that happen on any of my systems. Is it only when you're holding down the mouse button on the window?
#166009 - 24/06/2003 11:49
[Re: jbauer]
So how tough is it to add that "always on top" feature? Dunno, I'd have to look at her code first.
Oh, you mean in my app. Not tough. I just have to decide how to incorporate it into the UI. Should it be on the menu or in the dialog box?
#166010 - 24/06/2003 11:58
Yeah. Like if you were trying to drag the window but not actually moving it. It only happens sometimes though.
- Trevor
#166011 - 24/06/2003 12:06
Loc: Texas, USA
