#169682 - 08/07/2003 16:17 red hat question
oliver
can i compile a kernel with red hat 9? The last time i compiled a kernel was with red hat 7, and i had to format that machine a long time ago.
#169683 - 08/07/2003 16:33 Re: red hat question [Re: oliver]
I see no reason you couldn't. What leads you to believe you can't?
Oh, wait. Was that the version of RedHat where they intentionally shipped the buggy compiler? ISTR that you could get another compiler package marked explicitly for compiling the kernel. If this is the case, the ``normal'' compiler will be 3.something whereas the kernel compiler will be 2.something, IIRC.
#169684 - 08/07/2003 20:56 Re: red hat question [Re: wfaulk]
mcomb
Loc: San Carlos, CA
That was RH 7.0. Unless they did it again?
-Mike
#169685 - 09/07/2003 20:36 Re: red hat question [Re: wfaulk]
oliver
I just figured a newer version would probably cause some sort of problem along the lines. I'm most likely trying to do something way over my head, but there is only one way to find out
