#16972 - 06/09/2000 19:18 ID3 Tags
Terminator
Loc: Dallas, TX
I just synched about 4 gig of music on my player. About half of the tags didnt carry over correctly-the tag from the last song in each playlist is assigned to every song in the playlist. Is this normal or did I do something wrong? I dragged and dropped the playlists into emplode from explorer.
Sean
#16973 - 06/09/2000 20:20 Re: ID3 Tags [Re: Terminator]
Liufeng
Loc: Alaska
What program did you use to set the tags in the first place? If you used ID3 tag extension you may have set every tag the same for a directory of Mp3s. I did the same thing when I was figuring out the interface. But if you know how to use it that is a very quick way to fix tags on many files at once.
Tom
Reg #2845: Mark 1 #00173, Mark 2 #119
Reg #2845: Mark 1 #00173, Mark 2 #119, Mark 2a
#16974 - 06/09/2000 21:34 Re: ID3 Tags [Re: Liufeng]
Terminator
Loc: Dallas, TX
I figured out what I did. I was using MpTagger to change all the dates on 700 songs. I havent figured out the interface completely yet, so i was editing them one by one. When I got to the last song in the list I was apparantly hitting something that copied that last tag to all the other tags in the list, overwriting the song titles. After another hours work i fixed them all.
Thanks,
Sean
#16975 - 07/09/2000 10:19 Re: ID3 Tags [Re: Terminator]
loren
I did that EXACT thing with MPTagger. The interface is a biatch to figure out, but once you do i found it to be the most powerful tagger around. The "guess from CDDB" feature saved me HOURS of tagging on my huge MP3 collection.
||| loren.cox
||| 080000446
||| 12GB blue
|| loren ||
#16976 - 07/09/2000 12:13 Re: ID3 Tags [Re: loren]
alear
Loc: Montana, USA, Bozeman
I also did this with Tag and rename. The interface is not bad at all, I just screwed up! There should be a undo history for these programs because the problem doesn't sound uncommon.
Alex Lear
Alex Lear
#16977 - 07/09/2000 12:54 Re: ID3 Tags [Re: alear]
loren
Actually, MPTagger had supposedly unlimited undoes...it's saved my ass a few times..heheh.
||| loren.cox
||| 080000446
||| 12GB blue
|| loren ||
