#171660 - 21/07/2003 19:13 V3 Alpha Juju de Morte
jimhogan
Loc: Seattle, WA, U.S.A.
For any V3 alpha covetors, I can say that all of those alpha disclaimers are worth the time it takes to read them. Ah, you see, Jim's Empeg #1, "Hugo", is now NO WORKY. le musica es DESPARACIDO.
In essence, the Empeg seems to work until you attempt to play more tnan one song. YES, I -- THE STUPID BOY -- decided to use V3 Emplode to move a few treasured OGGs on to the Empeg...and then all of the problems begin
A coincidental bad cable? Well, I have jiggled every cable within reach, and I see no cable-related evil messages in my boot logs.... FSCK? Well, I have FSCK the disks until the FAQs run out of laser toner! All I have left now is the dark, mysterious "Error 19" .... I have asked Mister Reiser about this, but no answer yet.
So, Am I suffereing from stupidity? What is it that I am missing in this log???
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 9, serial number 10102052)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005180).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-230, ATA DISK drive
hdb: IBM-DJSA-230, ATA DISK drive
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:08:0
4
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Vcb: 0x4086d000
Anyhow.....the Empeg boots, works, and allows synchs from Emplode *once*, but then freezes up and Emplode will crash if synch attempted again....
All of this notwithstanding, I still think that it is VERY COOL that V3 lives!
(edit: Oh and, yes, I downgraded to V2 for the purposes of troubleshooting. I just haven't run the bulider image yet!!!)
Edited by jimhogan (21/07/2003 19:32)
Jim
#171661 - 21/07/2003 21:36 Re: V3 Alpha Juju de Morte [Re: jimhogan]
mtempsch
That bot log looks normal to me (after a quick scan)...
The reiser fs error 19 is perfectly normal - there's an attempt to mount the filesystem as a reiser fs, but since it is an ext2 filesystem, it of course fails (don't recall exactly why it tries the reiser fs, but it is normal)
#171662 - 22/07/2003 01:22 Re: V3 Alpha Juju de Morte [Re: mtempsch]
Because it's the same code that runs on Jupiter (Rio Central), where it would find a Reiser partition.
#171663 - 22/07/2003 06:45 Re: V3 Alpha Juju de Morte [Re: jimhogan]
My guess would be that your database is hosed. Try following the instructions to dlete the database found in this FAQ and then resync with emplode. You might also want to try JEmplode at this point (possibly after deleting the database again), as I seem to remember that it handles unknown file types a little better than emplode (but I might not be remembering correctly on this one).
Caveat lector: I've not done the database delete thing, and I don't quite remember if it has effects beyond simply cleaning out the database to be rebuilt. I don't think it does, but I could well be wrong.
#171664 - 22/07/2003 07:37 Re: V3 Alpha Juju de Morte [Re: wfaulk]
jimhogan
Yes, that's what I figured. Curiously, I went through that db/tag/playlist delete routine once yesterday and again this AM, and, in each case, when I run Emplode after the fact my playlists are still there (not what i expected after deleting /drive0/var/playlists!.....hmmmm, if this is normal I guess that means that the DBs/playlists are rebuilt from FIDs?)
(the fact that /drive1/var/* weren't found I chalked up to this player not having enough music to fill more than the 1st drive....)
Now that I hadn't considered....and I do have some "unknown" OGG files on the player now that v2 player/Emplode would not recognize...
Well, I'm way beyond caveats now! Anything short of a builder install I would consider a win. Hmmm, I may pop a spare laptop drive in this unit and run builder just to make sure I don't have a coincidental hardware problem. As it stands now, the symptoms are that the player starts normally, and menus may operate normally for a bit, but the player and display lock up after 1 song or any attempt to change the song/playlist. Certainly sounds like a DB problem.
Oh, the Pollyanna side of this? VMWare rocks. I used the "official" Empeg upgrade tool and was able to use that and Hyperterm under VMWare -- both were talking to "COM3" on a Comtrol Rocketport 8Si IP terminal server. The Comtrol Windows drivers seem to work just swell with the VMWare virtual IP.
(This is really good news as I have a bunch of infrequently used Windows utilities such as for Icom+Kenwood radio programming that require a COM port but which I don't want to reboot for)
Jim
#171665 - 22/07/2003 07:43 Re: V3 Alpha Juju de Morte [Re: jimhogan]
What's your host OS, there, Jim? (BTW, I've used VMWare as long ago as, I think, four years, and it rocked then.)
#171666 - 22/07/2003 07:44 Re: V3 Alpha Juju de Morte [Re: jimhogan]
Exactly, and I didn't say it, so my advice would be to delete those files ASAP and then try rebuilding the database again.
#171667 - 22/07/2003 07:50 Re: V3 Alpha Juju de Morte [Re: jimhogan]
That may not be the case. See this FAQ.
#171668 - 22/07/2003 08:48 Re: V3 Alpha Juju de Morte [Re: wfaulk]
jimhogan
Running Redhat 9 dual-boot with Win2K, but I pretty much kept native Win2K for some video tools that I do not use frequently. I run Win2K under VMWare and have my /home Samba mounted so that I can mount it from the virtual machine. Likewise, although I don't use a browser much in the VM, it is pointed at the proivoxy/squid proxy on the host machine.
FWIW, I sprang for the recent VMWare 4 upgrade and feel like I got my $100 worth. Lots of small things seem better. I tend to park VMWare on a designated "Windows" desktop and leave it running, so I may have to succumb to the temptation to add another 512MB stick of RAM...
Jim
#171669 - 22/07/2003 08:56 Re: V3 Alpha Juju de Morte [Re: Roger]
jimhogan
A ha! And that is the case. Lots of FIDs on /drive1, just nothing in var.
My playlists are sooooo simple, I am tempted to start fresh, let the builder clean house.
Jim
#171670 - 22/07/2003 09:24 Re: V3 Alpha Juju de Morte [Re: jimhogan]
just nothing in var
Ah, I misread your earlier post. To clarify: You'd expect to find nothing in /drive1/var, regardless of the content on the disk. You might see files in here if you've added another disk, and this disk was previously the primary.
Files in /drive1/var should be harmless, but there have been reports of oddness. Delete them if you're feeling paranoid.
The database and playlists are stored in /drive0/var, and can be completely rebuilt from the data in the *1 files stored in the 'fids' directories.
The music is kept in /drive0/fids and /drive1/fids and is distributed as described in that FAQ entry.
#171671 - 22/07/2003 09:30 Re: V3 Alpha Juju de Morte [Re: jimhogan]
Jim, after deleting the database/tags/playlists files off the player, you must re-synch with emplode once to get it to rebuild them properly.
It'll rebuild them on-the-fly each boot, but they won't get written to the hard disk unless you synch with emplode.
If you're having trouble with doing that with emplode 3.0, it is safe to go back to emplode 2.0 and use that.
#171672 - 22/07/2003 09:31 Re: V3 Alpha Juju de Morte [Re: tfabris]
Can't you just set the drives as read/write and run the player application from command line? That always works for me.
#171673 - 22/07/2003 09:37 Re: V3 Alpha Juju de Morte [Re: pgrzelak]
Yeessss, but we don't tell people that because of the risk of them corrupting their filesystems by not rerunning the player before powering off. Manually remounting the filesystems read-write is one of the traditional borderlines between a consumer-level tech-supportable situation and a geek-level you're-on-your-own situation...
That's why the FAQ (last I looked) still tells people to use Emplode/Emptool to fix the database: so that nothing except our own software ever sees a read-write mounted filesystem.
#171674 - 22/07/2003 09:49 Re: V3 Alpha Juju de Morte [Re: tfabris]
jimhogan
Jim, after deleting the database/tags/playlists files off the player, you must re-synch with emplode once to get it to rebuild them properly....
....If you're having trouble with doing that with emplode 3.0, it is safe to go back to emplode 2.0 and use that.
I followed enough of the fabulous FAQs to cover these angles so far, and I reverted everything to V2 about a day and a half ago. The emplode on the CD just kept abeninding when I tried post-DB-delete resynchs so I went back to V2. The one thing I haven't tried is jEmplode synching as, for some reason that I won't recognize until I've had some lunch, my JRE seems hosed up....
I may momentarily cease to perseverate and go the builder route, unless there is any communal diagnostic value in more persistent perseveration. One good Jim side-effect is that I have learned a few things about the Empeg that I should have learned long ago!
Jim
#171675 - 22/07/2003 09:51 Re: V3 Alpha Juju de Morte [Re: peter]
Hahahaha. Valid point. A sign "abandon all hope ye who enter here".
#171676 - 22/07/2003 09:54 Re: V3 Alpha Juju de Morte [Re: peter]
Um, actually, it's not in the FAQ because I hadn't thought of it. Paul's mention is the first I'd heard of it.
So what would be the correct commands for doing it that way?
Let's see, I was thinking of editing that FAQ entry a bit anyway, so how's this for a proposed rewrite:
    You should be at a shell prompt now. Enter:
    rwm (There will be a long pause)
    rm /drive0/var/database
    rm /drive0/var/database3
    rm /drive0/var/tags
    rm /drive0/var/playlists
    rm /drive1/var/database
    rm /drive1/var/database3
    rm /drive1/var/tags
    rm /drive1/var/playlists
    (Note that some of those RM commands will not work, that's OK)
    /empeg/bin/player
    (The player application will run and rebuild the databases)
    q
    (This should exit the player application back to the shell prompt)
    rom
    exit
Is that the correct procedure? Should that work?
#171677 - 22/07/2003 10:01 Re: V3 Alpha Juju de Morte [Re: tfabris]
It's not the correct procedure, and it's not likely to work. That's a good example of why I'd prefer this player feature wasn't mentioned in the FAQ, because it'd only encourage people to make stuff up which won't work.
(The problem is that you shouldn't run the player from the shell, as that'll use up too much memory, especially if the player is rebuilding the databases; you should use exec to replace the shell with the player, or just ^D the shell. But I stand by the suggestion that the FAQ shouldn't mention any database rebuild method except doing a full synchronise.)
#171678 - 22/07/2003 10:03 Re: V3 Alpha Juju de Morte [Re: peter]
Okay, what if I did EXIT instead of /empeg/bin/player ?
edit: tried it, it seemed to work... Thanks for the warning about memory...
#171679 - 22/07/2003 10:09 Re: V3 Alpha Juju de Morte [Re: tfabris]
Well, not good...
Basically, if you set to read/write and exit, you will mark the filesystems as dirty and force and fsck. Highly annoying.
While it may not be the right way to do it, I have gone to shell, rwm'ed the music partitions, deleted the database files and run the player app from command line. I have not had it fail on me with either Mark2 or Mark2a players. Granted, if you have additional software in the background, it might cause memory problems.
One trivia note - when you q out of the player application run from command line, it is very graceful and sets the filesystems back to read only. So, if you were planning on doing additional work, you need to rwm them again...
Edit: I do this all the time keeping the players in sync with rsync. After the rsync completes, I used to run the player app while read/write, quit out, set the filesystems read/write again and then run swapon and mirrordb (symlink tree builder). Now, though, I am too lazy and just rsync the database files too...
Edited by pgrzelak (22/07/2003 10:10)
#171680 - 22/07/2003 10:11 Re: V3 Alpha Juju de Morte [Re: pgrzelak]
I just tried it, and I didn't get the dirty filesystem problem. It didn't complain about needing to FSCK, even after a power cycle and going back to the shell and RWM'ing again.
#171681 - 22/07/2003 10:15 Re: V3 Alpha Juju de Morte [Re: tfabris]
Wow! I could have sworn that marked them as dirty. Did you do a "sync" command or do any filesystem work between the rwm and the exit? That might be it.
In any case, a big disclaimer of "Don't try this at home" would be appropriate. I conceed the point - this is not for anyone who is unfamiliar with unix, or would mind blowing their filesystems to billions of random bits.
#171682 - 22/07/2003 10:29 Re: V3 Alpha Juju de Morte [Re: pgrzelak]
No, I didn't. I did the commands as I listed above in the thread, except I replaced "/empeg/bin/player" with "exit", and it all seemed to work.
Of course, I wasn't having disk trouble when I did it. I'm guessing people who are having trouble with their databases might also be having disk trouble, so I should beef up the FAQ entry regarding FSCKing before you do this.
While I also concede Peter's point, I have the following philosophy regarding this:
- Synching once with emplode should have taken care of it in the first place.
- If that didn't work, we're already in "problem" territory and we need to get this dealt with.
- We're already telling them to RWM the drives and delete files. From there, it's not a big step to exit the shell and have the player app fire off a database rebuild.
- Some people have reported getting Emplode working to synch when they're having these kinds of problems. In fact, these kinds of problems might be caused by problems with emplode. So if they need to do this procedure at all, it's actually better if we can leave emplode out of the equation.
Does anyone have any other warnings with regard to doing it that way?
#171683 - 22/07/2003 10:34 Re: V3 Alpha Juju de Morte [Re: tfabris]
And, as I remember, that's the exact situation where that FAQ was added. Emplode syncing didn't work, but that procedure did.
#171684 - 22/07/2003 14:38 Re: V3 Alpha Juju de Morte [Re: tfabris]
In my experience, it is not only safe, but mandatory.
YMMV.
