For any V3 alpha covetors, I can say that all of those alpha disclaimers are worth the time it takes to read them. Ah, you see, Jim's Empeg #1, "Hugo", is now NO WORKY. le musica es DESPARACIDO.
In essence, the Empeg seems to work until you attempt to play more tnan one song. YES, I -- THE STUPID BOY -- decided to use V3 Emplode to move a few treasured OGGs on to the Empeg...and then all of the problems begin
A coincidental bad cable? Well, I have jiggled every cable within reach, and I see no cable-related evil messages in my boot logs.... FSCK? Well, I have FSCK the disks until the FAQs run out of laser toner! All I have left now is the dark, mysterious "Error 19" .... I have asked Mister Reiser about this, but no answer yet.
So, Am I suffereing from stupidity? What is it that I am missing in this log???
empeg-car bootstrap v1.02 20001106 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 9, serial number 10102052)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005180).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-230, ATA DISK drive
hdb: IBM-DJSA-230, ATA DISK drive
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:08:0
4
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Vcb: 0x4086d000
Anyhow.....the Empeg boots, works, and allows synchs from Emplode *once*, but then freezes up and Emplode will crash if synch attempted again....
All of this notwithstanding, I still think that it is VERY COOL that V3 lives!
(edit: Oh and, yes, I downgraded to V2 for the purposes of troubleshooting. I just haven't run the bulider image yet!!!)
