I recently hacked up the intercept program from the developer-site to let the empeg listen to my own "100 in 1"-remote.
It works... I can use the same remote that I use for my TV and video. The only problem is the response-time...
I sometimes have to wait half a second before commands are sent through.
This isn't much of a problem using the remote, but it also applies to the front button. When I turn up the volume it can get very ( too ) loud at once...
I think the problem is in process-scheduling. I also tried nice values of -20 with no success. As long as the empeg isn't playing there is no delay, but the player process probably uses too much CPU.
I haven't downloaded any kernel-image yet, but I presume it should be possible to hack up the ir-driver to read a file at boot to map ir-codes to the empeg-remote codes, wouldn't it???
Frank van Gestel
Frank van Gestel
