Im selling my home docking unit (home made by myself). It includes an
original sled.
See pics at:
http://www.blackrockdesign.co.uk/empeg/dock.htm
It is black, and standard hi-fi seperates size (W: 435mm D: 295mm H: 85mm) and so fits in well with existing hi-fi.
It includes:
- an original sled, with all wiring intact (DIN connectors used so none of the cables have been cut).
- connections for RCA out, ethernet, serial, power and also has the space and wiring to add AUX input very easily.
- The power supply is contained within the box (original un-modified empeg one) and wired so you simply attach a standard PC power cable. It also has hard-power button with power LED on the front.
- it is made from MDF, with a sprayed aluminium front bezel for a perfectly smooth finish.
Going to start at £150+shipping to wherever, but it needs to go so make me an offer.
