#179981 - 19/09/2003 11:33 Hijack Config
Narkotic
Hey guys, is there any way to disable the force DC power mode w/out using the front display? Where does hijack store its configurations... i looked in the config file for the empeg but didn't see anything in particular. Thanks;
#179982 - 19/09/2003 11:40 Re: Hijack Config [Re: Narkotic]
Mark stores that stuff in flash. You'd have to have some little program to write a single bit (or maybe 2 bits) to the flash. Wouldn't be terribly hard to do but if you write to the wrong flash location, you might end up screwing something up.
#179983 - 19/09/2003 13:23 Re: Hijack Config [Re: tonyc]
Narkotic
hmm... if that were the case, then I should also just be albe to re-load the firmware on the player then reload hijack and it should be back to defaults? I tried that and it still stayed on dc power mode.
#179984 - 19/09/2003 13:24 Re: Hijack Config [Re: Narkotic]
The flash area it's saving to isn't affected by upgrades. The upgrader only puts the kernel into flash and doesn't touch the rest of the memory.
#179985 - 19/09/2003 13:25 Re: Hijack Config [Re: Narkotic]
IIRC, the 128-byte flash block doesn't get erased/initialized by a firmware upgrade.
#179986 - 19/09/2003 13:26 Re: Hijack Config [Re: Narkotic]
What exactly is your intended application? Why do you want to use something else other than the front panel to control that?
#179987 - 19/09/2003 13:27 Re: Hijack Config [Re: tfabris]
I'd say he's trying to do it because he's the one that extended the display cable and blew something...
#179988 - 19/09/2003 13:28 Re: Hijack Config [Re: tfabris]
Just thinking of something actually... does the VNC server display the hijack overlays or does it just do the normal player display?
#179989 - 19/09/2003 13:29 Re: Hijack Config [Re: tman]
Narkotic
You are correct.
#179990 - 19/09/2003 13:31 Re: Hijack Config [Re: tman]
Narkotic
The VNC server is something I would have to install, correct? I dont think thers any way to do that while the player is in DC mode, because FTP and HTTP are disabled... which is why I want to disable force DC mode.
Any programmers want to try and make me a little piece of flash code that would change the bit for me?
#179991 - 19/09/2003 13:37 Re: Hijack Config [Re: Narkotic]
If ethernet works, use my EmpegFace utility at my home page.
#179992 - 19/09/2003 13:43 Re: Hijack Config [Re: Narkotic]
genixia
Possibly,
If you hadn't used any other hijack feature since forcing the power mode then you can do it fairly easily by touch.
Boot up.
Long press knob.
Short press knob,
Cycle mode (Right knob click cycles Normal->AC->DC->Normal ad infinitum).
Short press knob,
Press left and right buttons together. (should reboot)
If you have used another hijack feature since forcing the power mode, then this wont work. If you can remember what feature it was then we should be able to count through them too.
#179993 - 19/09/2003 14:34 Re: Hijack Config [Re: genixia]
Narkotic
I have NO display face on whatsoever. No buttons, no VFD, nothing. But thanks
#179994 - 19/09/2003 14:36 Re: Hijack Config [Re: tfabris]
Narkotic
That will not work because I would need HTTP or FTP services, which Hijack disables when in DC_Carmode.......
#179995 - 19/09/2003 14:38 Re: Hijack Config [Re: Narkotic]
If you just want the FTP and HTTP servers you could just put "dc_servers=1" into the hijack section of your config you know...
It's in the Hijack FAQ
#179996 - 19/09/2003 14:57 Re: Hijack Config [Re: tman]
Narkotic
Well I thought that would work (it should), but it does not. UGH
#179997 - 19/09/2003 15:03 Re: Hijack Config [Re: tman]
Narkotic
GOT IT! I owe you a beer man.
#179998 - 19/09/2003 15:04 Re: Hijack Config [Re: tfabris]
Narkotic
BTW, Tony. This program you made kicks ass. Thanks for giving me a virtual face until I get the real one fixed.
#179999 - 19/09/2003 15:15 Re: Hijack Config [Re: Narkotic]
No problem! Glad you've got a temporary solution. Sorry I don't know how to fix the actual hardware, since you've done all the things I know about (checking fuses etc).
#180000 - 19/09/2003 15:28 Re: Hijack Config [Re: tfabris]
mwest
Loc: Ada, Oklahoma
WHOA... WHERE'VE I BEEN... EMPEGFACE IS AWESOME!!!!!!!!
-Michael West
#180001 - 19/09/2003 15:34 Re: Hijack Config [Re: mwest]
Thank you! I'm glad you like it!
Dunno why I decided to code it when there were already other perfectly-good remote-control applications available. Sometimes I just get this wild hair to make a little VB app and it just hit me then. If I recall correctly, it did so at an inconvenient time, when I was preparing for the trip to Europe.
#180002 - 19/09/2003 15:35 Re: Hijack Config [Re: mwest]
Um, Oklahoma?
<runs for cover>
#180003 - 22/09/2003 14:12 Re: Hijack Config [Re: mwest]
mwest
Loc: Ada, Oklahoma
Hey Tony... have you ever thought of button hacking EmpegFace?
-Michael West
#180004 - 22/09/2003 15:27 Re: Hijack Config [Re: mwest]
It's freeform skinnable. You can do anything you want with the buttons.
#180005 - 22/09/2003 15:33 Re: Hijack Config [Re: JBjorgen]
Actually, I do have a version of the skin that is a photo of my buttonhacked face. Dunno if I included it in the last release of the software or not. If so, the skin would be called "photo" in the zip file. If not, I can post it here if there's interest.
#180006 - 22/09/2003 15:37 Re: Hijack Config [Re: tfabris]
Just checked it-- the last version does in fact have the buttonhacked face as an available skin. Just go into the config screen and enter "photo" for the skin.
#180007 - 22/09/2003 15:45 Re: Hijack Config [Re: tfabris]
mwest
Loc: Ada, Oklahoma
Very cool... Thanks... It looks great. My network is goofing me up though. The program is having trouble refreshing. If I open Emplode it refreshes and goes for a while and then hangs again.
-Michael West
#180008 - 22/09/2003 15:52 Re: Hijack Config [Re: mwest]
Hmm, I never tested it simultaneously with Emplode...
