#182708 - 03/10/2003 14:33 dead drive?
Cambscar
Loc: Cambridge, UK
Hi all,
Work stuff's kept me so busy lately I somehow missed the fact that v3 player software had been leaked until I saw Hugo for the first time in ages today. On finding out about it, I came home tonight with the intention of upgrading to find out what's new.
The initial install went OK, but I found that the player was 'building player database' on every boot, hanging for a fraction of a second quite often during playback, and that the drive heads were making a clicking very regularly at about a second intervals. I then decided to revert to v2, and to repeat the whole process to see if things stayed the same.
On doing so, Emplode hung during the install process. The flash programming part all seems to go OK, but once it reaches the pumping partition process, it takes forever to pass "Finding pump (preparing first hard disk)", and once that does eventually complete,
"Selecting pump device" just times out with the error "Bad pump response during stage 0x25".
Attempting to connect to a shell doesn't get any further than the boot message (see below) and about the only thing I can do is get to a Pump> prompt during boot using CTRL-A. If you try and boot the player, either in car or off the power supply you get the initial boot screen, the player hangs at the boot logo, then finally shows "no hard disk found contact support"
I've physically checked the IDE connector and cable, and all seems OK there. The obvious question- have I somehow managed to stuff the disc?? You can hear that it spins up initally on power up OK.
Anyone got any suggestions, or do I face the drive into work tomorrow with no music?
Dominic
empeg-car bootstrap v1.00 20000601 ([email protected])
On DC power, quick boot
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg54 (rob@tatu) (gcc version 2.95.3 20010315 (release)) #19 Wed Jul 2 23:26:54 BST 2003
empeg-car player (hardware revision 7, serial number 90000930)
Command line: mem=12m noinitrd
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005b80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:a2
VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
#182709 - 03/10/2003 14:40 Re: dead drive? [Re: Cambscar]
Don't panic. Pump errors are discussed here.
#182710 - 03/10/2003 14:43 Re: dead drive? [Re: Cambscar]
The kernel's not seeing a hard drive at all. Check the FAQ for possible reasons.
#182711 - 03/10/2003 15:22 Re: dead drive? [Re: tfabris]
Cambscar
Loc: Cambridge, UK
Hi Tony,
I just swapped the drive out for an old one I've got kicking around, and it's now working fine. Well, fine's probably not the right word for an Empeg with 540mb, but it works
I guess it's time to have a hunt around on eBay.
Dominic
#182712 - 03/10/2003 15:43 Re: dead drive? [Re: Cambscar]
Before assuming that the drive is bad, try putting the original one back in and seeing if it magically starts working. At that point, suspect the cable or the IDE header before assuming that the drive is bad.
I mean, bad drives are possible, but problems with the cable and the IDE header are more likely.
#182713 - 03/10/2003 16:03 Re: dead drive? [Re: tfabris]
Cambscar
Loc: Cambridge, UK
Yep, tried that too. I've swapped back and forth a couple of times. The original drive consistently doesn't work. The other consistently does. The thing that really made me decide that the player wasn't happy running v3 in the first place were the noises the drive was making. I'm sure it's in some way related to the whole upgrade process as it's been faultless up to now.There's no way I'd even consider saying it was caused by it though. Could just be that it wasn't 100 percent to start with, and the extra load during the upgrade was too much for it. Or possibly even me doing something stupid I've not realised yet. Either way, Rob couldn't have been any clearer in the readme. I'm just gutted that I'm going to have to wait until I find another drive before I can play with v3 now!
Dominic
