Turn Off CD Auto Play Win2000 the Microsoft way
Click Start, click Run, type regedit in the Open box, and then press ENTER.
Locate and click the following registry key:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1.
Restart your computer.
NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD.
Additional Information
There are two other registry keys that can affect this functionality:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
NoDriveTypeAutoRun = 0x00000095
-and-
HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
The correct value for each is 0x00000095.
from
here
