#188496 - 06/11/2003 18:43 DVI, USB, KVM
Does anyone have a DVI, USB, KVM that works good ?
I bought a belkin one and the video periodically filckers and has lines. A two station one is fine I would like dual head but the only one I have seen was pointed out by Drakino and it far too expensive.
I have found other switches with DVI but I don't know if they have the same problem.
Edit:
Or if I can't find a good dvi one are there devices so I could just share the mouse and keyboard between the two computers without video.
Edited by msaeger (06/11/2003 18:49)
#188497 - 07/11/2003 04:31 Re: DVI, USB, KVM [Re: msaeger]
Geoff
Loc: Northern Ireland
I have a Belkin KVM (not DVI though) and used to get terrible flicker on my LCD monitor, lots of horizontal lines and interference - it was almost unusable at times. I finally worked out that I had to change the refresh rate. I can't remember the refresh rates involved, but the display is rock solid now. It might be worth experimenting with different refresh rates if you haven't ruled that out already.
But as I say, I don't have DVI or know much about it, so maybe refresh rates are irrelevant.
Geoff
Mk1 Blue - was 4GB, now 16GB
Mk2 Red - was 12GB, now 60GB
#188498 - 07/11/2003 07:38 Re: DVI, USB, KVM [Re: Geoff]
What did you change it to ?
#188499 - 07/11/2003 07:43 Re: DVI, USB, KVM [Re: msaeger]
treadlove
On my setup, the LCD monitor has a reset function. That does the trick for me.
#188500 - 07/11/2003 09:45 Re: DVI, USB, KVM [Re: msaeger]
Geoff
I can't remember what it's set to off the top of my head.
I think that it flickered like crazy at 1024x768/75Hz and now works fine at 1024x768/70Hz. The monitor is an LG-563LE 15" lcd model in case that is relevant.
I'll check later when I get home.
Geoff
#188501 - 07/11/2003 17:24 Re: DVI, USB, KVM [Re: msaeger]
ineedcolor
Loc: Windsor, Ontario Canada
I have this one (not DVI tho) connecting my main system to my music server. It has been working like a champ for about 8 months now....one of the best hardware choices I've made in a while
#188502 - 11/11/2003 13:46 Re: DVI, USB, KVM [Re: ineedcolor]
JBCP
Loc: New Jersey
Use software! I had this same sort of issue and found some software which runs on the network:
http://fredrik.hubbe.net/win2vnc.html
When running you can move mouse from one screen to the next as if you have dual montiors, but really your keyboar, mouse, and copy/paste buffer is moving from one machine to the other - really cool stuff.
Jeremy Briggs www.carplayer.com
#188503 - 12/11/2003 03:56 Re: DVI, USB, KVM [Re: JBCP]
Yeah but don't you still need two monitors? Which is cool, but might not be what the OP wants.
Ironically, I do the exact opposite -- I have dual monitors on my Windows box, and I run VNC viewer full screen on one of them.
