#189615 - 15/11/2003 09:18 Pocket PC + Bluetooth + desktop
CrackersMcCheese
What I have
Toshiba Pocket PC with CF Bluetooth card
Dell desktop with MSI USB Bluetooth dongle
Netgear RP114 providing Dell and other 3 machines with Internet access
What I want to happen
Access the Internet on Pocket PC using the Dell's Internet connection
I can get it to access files etc, and I can see its connected in Bluetooth Manager, just no Internet is available.
I'm having a problem sharing the Dell's connection as shown in attachment.
#189616 - 15/11/2003 10:21 Re: Pocket PC + Bluetooth + desktop [Re: CrackersMcCheese]
My guess is that the 192.168.0.x network you're using for the Dell and your other machines to access the internet is the same network that ICS wants to use. Change your normal internal network to use something else, like 192.168.1.x, and see if that helps.
Chances are that your router is using DHCP to hand out the addresses to your normally connected computers, so you'll probably have to modify its configuration to get the network to change. Assuming, of course, that your router allows you to change that network.
ICS might also allow you to change the network it uses, but I've got no idea how to do it even if it is possible, which it may well not be. (Although that ``Settings...'' button looks promising.)
