#191936 - 04/12/2003 14:31 Hard Disk Failure
mein_pappa
I have a MKII player which I've owned for almost three years and upgraded with a second drive 18 months ago and this morning the player boots up to the Hard Disk Not Found error. I read the FAQ and made the requisite visual inspections and didn't find much. I also connected to the console via HyperTerm and this is what I got:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v347 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sun Nov 23 12:29:03 EST 2003
empeg-car player (hardware revision 9, serial number 10101159)
Command line: mem=16m
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005180).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: HITACHI_DK23DA-30, ATA DISK drive
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
hdb: HITACHI_DK23DA-30, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:04:8
7
Partition check:
hda: hda1 <hda: read_intr: status=0x59
hda: read_intr: error=0x10
ide0: reset: success
end_request: I/O error, dev 03:01 (hda), sector 0
> hda2 hda3 hda4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
It would appear that my hard disks are being found but an area of my disk has been damaged. Is this accurate? Is there any way I can save my MP3 collection w/o having to reload?
Thank you in advance for any support.
#191937 - 04/12/2003 14:35 Re: Hard Disk Failure [Re: mein_pappa]
Please read this FAQ.
#191938 - 04/12/2003 14:40 Re: Hard Disk Failure [Re: wfaulk]
mein_pappa
I read through that and looked at both the cable and the solder joints and all apears okay. Plus, the boot log shows that it located both hard disks but that it's getting a read error some of the time. This, to me, would kind of indicate bad sectors on the disk - is this correct? Or would it still be a good idea to try a new cable?
I know my way around a Windows box (which I know doesn't hold much water around here ) but I'm completely at a loss when exposed to a linux system.
#191939 - 04/12/2003 14:41 Re: Hard Disk Failure [Re: wfaulk]
He says he did read the faq and that a visual inspection didn't find much. Which isn't saying much...
#191940 - 04/12/2003 14:42 Re: Hard Disk Failure [Re: mein_pappa]
ISTR some folks not being able to see a problem with their cables but they didn't work anyway. That's probably the first thing to try.
#191941 - 04/12/2003 14:43 Re: Hard Disk Failure [Re: mein_pappa]
Maybe. Or it could indicate an intermittent connection problem that has nothing to do with bad sectors.
Or squeezing the existing one..
#191942 - 04/12/2003 14:43 Re: Hard Disk Failure [Re: tfabris]
Sorry. Knee-jerk.
#191943 - 04/12/2003 14:44 Re: Hard Disk Failure [Re: wfaulk]
Hey, I've done it before too, so no worries.
#191944 - 04/12/2003 14:47 Re: Hard Disk Failure [Re: wfaulk]
mein_pappa
Thank you oh, long bearded wizened ones.
I'll try giving this one a sqeeze with some C Clamps and see what happens while I order a new cable.
#191945 - 04/12/2003 15:16 Re: Hard Disk Failure [Re: mein_pappa]
loren
Run a disk check?
|| loren ||
#191946 - 04/12/2003 15:18 Re: Hard Disk Failure [Re: loren]
I wouldn't do that until I was certain there wasn't a hardware-level problem.
#191947 - 04/12/2003 15:23 Re: Hard Disk Failure [Re: tfabris]
loren
I would because it doesn't look like it's having any problems seeing the disks. Anyhow, i'd give that a shot after you tighten down those crimps.
|| loren ||
#191948 - 04/12/2003 15:40 Re: Hard Disk Failure [Re: loren]
mein_pappa
How does one run a disk check?
#191949 - 04/12/2003 15:42 Re: Hard Disk Failure [Re: loren]
All that read_intr stuff is hardware error. An fsck at this point is not going to help.
#191950 - 04/12/2003 18:16 Re: Hard Disk Failure [Re: wfaulk]
loren
I'll be in my corner.
|| loren ||
