Page 2 of 2 < 1 2
#194169 - 18/12/2003 19:25 Re: Hrmm Empeg not working [Re: kendrick]
kendrick
Now the self tests dont seem to wanna work.
#194170 - 18/12/2003 19:31 Re: Hrmm Empeg not working [Re: kendrick]
kendrick
ok, after tryin to do that a hundred times.
Now i get a red light , the blinkin blue light
and this came up
00000000000000000000000000000000000000000000000000000000000000000000000000000000MIPS
Memory: 15016k/16M available (980k
000000000000000000000000000000000000000000000000000000000000000000000000000000006384 (order 4, 64k)
Page ca
00000000000000000000000000000000000000000000000000000000000000000000000000000000rsity Computer Society NET3.039
00000000000000000000000000000000000000000000000000000000000000000000000000000000ocols: ICMP, UDP, TCP
TCP: Hash tables configured (e
00000000000000000000000000000000000000000000000000000000000000000000000000000000A1100 UART
ttyS02 at 0xf8030000
00000000000000000000000000000000000000000000000000000000000000000000000000000000ture is 206f6972 'rio '
Tuner: loopback=0, ID=-1
00000000000000000000000000000000000000000000000000000000000000000000000000000000sp audio initialised
empeg dsp mixer initialised
00000000000000000000000000000000000000000000000000000000000000000000000000000000initialised, CS4231A revision a0
00000000000000000000000000000000000000000000000000000000000000000000000000000000ram disk... done.
VFS
00000000000000000000000000000000000000000000000000000000000000000000000000000000v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Mo
Freeing unused kernel memory: 4k initHijack: intercepting confi
empeg-car bootstrap v1.02 20001106 (hugo@empeg.c
00000000000000000000000000000000000000000000000000000000000000000000000000000000 who wants to upgrade the flash, let them speak now,
00000000000000000000000000000000000000000000000000000000000000000000000000000000-0000047200000000000000000000000000000000000000000
0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
If there is anyone present who w
or forever hold their peace...
00000000000000000000000000000000000000000000000000000000000000000000000000000000peg.com>
0100 ra
0120 testing ic 2 (0-15mb, high word)
00000000000000000000000000000000000000000000000000000000000000000000000000000000nts to upgrade the flash, let them speak now,
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v347 (root@ibbm)
.3 20010315 (release)) #2 Sun Nov 23 12:29:03 EST 2003
00000000000000000000000000000000000000000000000000000000000000000000000000000000ision 11
NetWinder Floating Point Emu
empeg-car player (hardware revision 9, serial
SA1100 serial driver v
VFS
00000000000000000000000000000000000000000000000000000000000000000000000000000000 present who wants to upgrade the flash, let them speak now,
00000000000000000000000000000000000000000000000000000000000000000000000000000000peace...
0000 empeg-car (issue9) board test versio
0100 ram test starting
0110 testing ic 1 (0-15mb, l
e000 v1.04
#194171 - 18/12/2003 19:34 Re: Hrmm Empeg not working [Re: kendrick]
kendrick
So then after another few tries, i got it to self test again and i get this
0000 empeg-car (issue9) board test version 0.05 <hugo@empeg.com>
0110 testing ic 1 (0-15mb, low word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id FUJITSU MHM2100AT
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 29
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
#194172 - 18/12/2003 19:35 Re: Hrmm Empeg not working [Re: kendrick]
kendrick
And now its working again for now i guess.
Any ideas what all of this means?
#194173 - 18/12/2003 19:43 Re: Hrmm Empeg not working [Re: kendrick]
kendrick
And not working again.
#194174 - 18/12/2003 19:55 Re: Hrmm Empeg not working [Re: kendrick]
kendrick
oohh goody, finally works again.
#194175 - 18/12/2003 19:56 Re: Hrmm Empeg not working [Re: kendrick]
kendrick
and not working again.
#194176 - 18/12/2003 20:00 Re: Hrmm Empeg not working [Re: kendrick]
kendrick
after a number of tries finally got the self test to work again
it gets this far then seems to freeze i guess since it doesn't continue any further
#194177 - 18/12/2003 22:12 Re: Hrmm Empeg not working [Re: kendrick]
Mmm... take it apart and check for frayed insulation on the displayboard ribbon cable (common problem, due to the drive tray rubbing against it).
Definitely the first thing to check.
#194178 - 18/12/2003 22:16 Re: Hrmm Empeg not working [Re: kendrick]
RobotCaleb
wow
the one with all the zeros is kinda scary
#194179 - 18/12/2003 22:42 Re: Hrmm Empeg not working [Re: RobotCaleb]
kendrick
Mlord, i checked both of those still no luck, everything looks fine.
How much do you charge to repair?
#194180 - 18/12/2003 23:25 Re: Hrmm Empeg not working [Re: kendrick]
kendrick
Think my memory has gone bad, blown fuse?
#194181 - 19/12/2003 08:07 Re: Hrmm Empeg not working [Re: kendrick]
Mmm.. I dunno. If it works fine for long periods of time *sometimes*, then the memory is probably just fine. Something else is wrong.
I don't have time to diagnose it in the near future -- kinda swamped with multiple contracts at the moment, the hourly rate for which would rapidly pay for several eBay Empegs -- so pin your hopes elsewhere for now. I can do quick solder replacements and the like, but diagnosing flakey hardware would take much much much longer.
#194182 - 19/12/2003 08:32 Re: Hrmm Empeg not working [Re: mlord]
Greetings!
It does sound like flakey memory at the moment. Unfortunately, I do not know of a better way to test for it. Either way, it will need to be looked at.
#194183 - 19/12/2003 09:27 Re: Hrmm Empeg not working [Re: pgrzelak]
kendrick
Well anyone have any other ideas of what could possibly be wrong
Page 2 of 2 < 1 2
