#195174 - 28/12/2003 16:41 jemplode47 and xml
RobotCaleb
if anyone would like to confirm this, please do. i can only test on one of my empegs.
when i export the database using Tools > Export Database to XML from jemplode it appears to truncate it early. how early, i can not tell as the xml given by jemplode and emplode differ.
also, it appears that jemplode grabs the 'player name' using the owners name. ie. my empeg is named 'Tabitha' and the name jemplode puts in the xml is 'Caleb' (which, obviously, is my name) like so
<player name="Caleb">
here is the tail end of the xml created from jemplode :
<tune id="x4c80">
<attribute name="duration">201573</attribute>
<attribute name="skip_count">0</attribute>
<attribute name="bitrate">vs301</
#195175 - 28/12/2003 17:31 Re: jemplode47 and xml [Re: RobotCaleb]
juenk
Loc: Waardenburg, The Netherlands
I did a quick test with jEmplode 47, and (Mk 2a/10Gb) cannot see any truncation.(both with the 'Export to XML' and 'Export to Emplode-XML' option).
Same here. Feature or Bug?
Jelle
Empeg M2A Blue # 010101908 80Gb
Empeg M2A Blue # 030102771 with backlight buttons - Need repair (IDE cable connection on main board) - volunteers?
#195176 - 28/12/2003 18:45 Re: jemplode47 and xml [Re: RobotCaleb]
mschrag
Loc: Richmond, VA
both bugs ... both fixed ... i guess i need to do a new release, huh ... It's been a while.
#195177 - 28/12/2003 18:51 Re: jemplode47 and xml [Re: mschrag]
RobotCaleb
cool, thanks.
