#19577 - 05/10/2000 22:44 Percent Complete Indication
geekdude
I miss having a percentage or a time remaining indicator
while listening to BIG (77MB) mp3 files.
Would like to see an option for time remaining, percentage,
and bit rate (160Kb)
-- MK2, 36G, blue, 080000398 --
#19578 - 06/10/2000 03:31 Re: Percent Complete Indication [Re: geekdude]
EngelenH
Loc: Belgium/Holland
Actually I had not put my finger on it yet, but reading it here it dawns to me, this is indeed something I miss too.
seconded.
Hans
Mk2 - Blue - 080000431
Mk2 This message will selfdestruct in 5 seconds to prevent reproduction.
#19579 - 06/10/2000 09:50 Re: Percent Complete Indication [Re: EngelenH]
Having a "time remaining" indicator is a common request.
They can't do this with the current XAudio decoding engine. However, 1.1 will be implementing a new engine which should allow this. I believe it's planned.
#19580 - 06/10/2000 13:42 "INDEX" in large mp3 files [Re: geekdude]
dionysus
Loc: San Francisco, CA
Personally, I'd love the ability to jump backwards or forwards 5 minutes at a time in large 60+minute mp3 files..
-mark
MK2: 36gb
Tivo: 90gb
CPU: 120gb
...I think drive manufacturers love me!
#19581 - 06/10/2000 17:59 Re: "INDEX" in large mp3 files [Re: dionysus]
geekdude
I would like this too.
Perhaps the longer you press the button the faster it could scan ?
#19582 - 06/10/2000 18:25 Re: "INDEX" in large mp3 files [Re: dionysus]
borislav
Loc: Sunnyvale, CA, USA
Heh, I'd be happy with working fast forward in rewind for VBR mp3s...
Borislav
#19583 - 07/10/2000 03:46 Re: "INDEX" in large mp3 files [Re: geekdude]
This is in 1.1, I'm not sure where the bounds are of accelleration, but it was done to make very long files easier to move through. VBR is pretty much sorted in 1.1 too.
#19584 - 07/11/2000 00:40 Re: Percent Complete Indication [Re: geekdude]
Fogduck
Loc: BC
Yah, its been flogged before, and I understand the 1.1 engine might support it, but here is a concrete place that we can all imagine a progress indicator:
The divider line in "Track" view mode. Have a piece of that (3-5 pixels) in brighter pixels that moves left to right, like the slider in WinAmp.
Getting further ahead of reality, make it blink when scanning within the track...etc.
MK2 #141, green, 12GB
- - - MK2 #141 12GB Queue #5723 (SOLD) MK2a 30GB + grn + tuner + blk empeg case
#19585 - 10/11/2000 18:41 Re: Percent Complete Indication [Re: Fogduck]
mgraven
Loc: SF Bay Area, California
You've got a Tivo, don't you.
#19586 - 12/11/2000 04:20 Re: Percent Complete Indication [Re: Fogduck]
muzza
How about the line appears at the bottom of the screen when ff or rw is pressed?
Also, a nifty trick from a Roland reverb is you press and hold the direction (eg. ff) and then press and hold the opposite button (rw) to make the increment larger.
These kind of front panel shortcuts would give a whole range of possibilities
____________________
Murray 06000047
#19587 - 12/11/2000 13:29 Re: Percent Complete Indication [Re: muzza]
fvgestel
Loc: Netherlands
Even nicer : let the rotary-control set the position in the file.
Frank van Gestel
Frank van Gestel
#19588 - 12/11/2000 18:49 Re: "INDEX" in large mp3 files [Re: borislav]
jwickis
Loc: India
I thought it did?
I find if you push the button longer it will eventually.
#090000695 Mk2 BLUE 12Gig
#19589 - 12/11/2000 18:49 Re: "INDEX" in large mp3 files [Re: borislav]
jwickis
Loc: India
I thought it did?
I find if you push the button longer it will eventually. I haven't tested with all VBR files though.
