#195788 - 03/01/2004 06:32 ffwd/rwnd reduces volume
Aragon
Loc: Cape Town, South Africa
Hi,
In case this feature hasn't already been suggested, could the player software reduce the output volume to, say, -30 (or by a certain amount relative to current volume) whenever one fast forwards or rewinds through a track? The process of fast forwarding is very harsh to listen to I find, especially with certain music at higher than low volumes.
Commercial CD players employ this trick I think.
Thanks,
Aragon
#195789 - 03/01/2004 14:08 Re: ffwd/rwnd reduces volume [Re: Aragon]
Mmm.. in the interim, you can probably implement this feature yourself using Hijack's IR translate functions, having them issue a HUSH (or mute) when the FF/REW are pressed, and the correspondiing un-hush/mute on release of the FF/REW.
#195790 - 04/01/2004 14:21 Re: ffwd/rwnd reduces volume [Re: mlord]
Aragon
Hi,
I can't get it working. I'm trying this:
Left.L=Hush,Left.L,Hush
Right.L=Hush,Right.L,Hush
When I try ffwd through a track, it hushes but does nothing. When I release the button it then starts ffwd'ing but does not stop until I interrupt it with, say, pause. Once interrupted it unhushes.
Is there a way to bind translations to actual up's and down's of keypresses? Can't see this in the FAQ.
Thanks,
Aragon
