#198371 - 14/01/2004 17:14 No Hard Disk Found - Contact Support
mvigneau
Loc: Manchester, NH
I am getting the dreaded. No Hard Disk Found...Contact Support.
I noticed the following line: Could not find CS4231A (version=80).
I looked at that chip and it looks like there are 2 connectors on this chip that have a solder bridge. I don't know if this is normal. I will try to take a picture but I don't think that it will come out right.
What should I do?
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v347 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sun Nov 23 12:29:03 EST 2003
empeg-car player (hardware revision 9, serial number 10101551)
Command line: mem=16m
Calibrating delay loop...207.67 BogoMIPS
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9b790
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004580).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
empeg state support initialised 0089/88c1 (save to d0004500).
smc chip id/revision 0x0049
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
#198372 - 14/01/2004 17:18 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
EDIT: Ignore the CS4231. Sod that.. this would be a problem also, but I dunno if it affects the IDE controller or not.
Check the hard disk cables -- make sure they are actually still connected. Listen for the drive: it should make clicking noises at startup, and you should also be able to clearly hear it spinning after power-on.
Next up is the infamous IDE header on the main board: they used surface mount rather than through-hole pins, and the result is that they tend to come off the pads after a while and may require resoldering.
Edited by mlord (14/01/2004 17:21)
#198373 - 14/01/2004 17:18 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
This is a known problem that happens with some players. Unfortunately, the only solution is a chip replacement.
If the player worked before, and has only started failing now, then the thing you think is a "solder bridge" between the pins is very unlikely to be the problem. It's probably supposed to be that way, or at least it doesn't hurt anything to have it that way.
#198374 - 14/01/2004 17:23 Re: No Hard Disk Found - Contact Support [Re: mlord]
mvigneau
Loc: Manchester, NH
I can hear the hard drive powering on with clicking noises and it continues to spin even after the "no hard disk found" message.
I am removing the hard drive now to check the cable and the header on the board.
#198375 - 14/01/2004 17:31 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
mvigneau
Loc: Manchester, NH
The cable looks fine and the solder joints look fine on the IDE Header.
How would i get a new CS4231A-KQ Chip? It is SMT and has quite a few things to solder. I am pretty good at soldering, but not that good.
#198376 - 14/01/2004 17:34 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
You can have support do the repair when he re-opens. Alternatively, see if Stu can do it for you.
#198377 - 14/01/2004 18:39 Re: No Hard Disk Found - Contact Support [Re: tfabris]
maczrool
Loc: Louisiana, USA
Hugo was supposed to send us some, but they never turned up so I don't know if he sent them or not. I'll have to ask him and see. We did have some on order, but cancelled it.
As for the bridges, if I remember correctly, that is present on all players and not a cause for alarm.
Stu
#198378 - 14/01/2004 20:52 NEW CABLE installed now it wont power up [Re: mvigneau]
bsieloff
Loc: Chicago
YIKES. my empeg player started showing the hard disk not found about 1.5 years ago. I emailed support and they said it was the cable and sent me a new one. I finally got around to putting it in last week and when I went to start up the player it would not power up. I have found if I remove the HD the player will start up, therefore it would seem the player is fine. Is there something I missed when putting the player back together?
#198379 - 14/01/2004 21:19 Re: NEW CABLE installed now it wont power up [Re: bsieloff]
mvigneau
Loc: Manchester, NH
When I remove the HD from mine, it still won't start up. I would look at your solder connection on the IDE header to see if they are good and check the cable to make sure it is fully crimped.
#198380 - 14/01/2004 21:19 Re: NEW CABLE installed now it wont power up [Re: bsieloff]
Yes.
It is highly likely that when you plugged the cable into the disk drive you were off by one pin.
This is amazingly easy to do, because (at least with the IBM drives) when the cable is mis-aligned it actually looks "better" than when it is on correctly.
You are certainly not the only one to have done this (if indeed this is the problem) and the good news is that this will not harm the disk drive nor the electronics in the player.
#198381 - 14/01/2004 21:37 Re: NEW CABLE installed now it wont power up [Re: tanstaafl.]
bsieloff
Loc: Chicago
False Alarm! I talked nice to it, and pulled the cable and reseated it. I will let you know if this cable resolves my initial harddrive boot problem. It seems to have the most problems during the winter months.
thanks for your help
Edited by bsieloff (14/01/2004 21:44)
#198382 - 15/01/2004 04:04 Re: No Hard Disk Found - Contact Support [Re: mlord]
David
Loc: Cambridge
The CS4231 shares a power line with the IDE controller (or something, I'm starting to forget everything I learned) which means if it fails, it can cause IDE problems.
There may be another problem, but replacing the chip is likely to be necessary.
#198383 - 15/01/2004 09:32 Re: No Hard Disk Found - Contact Support [Re: David]
Mmm.. I wonder if maybe it's just the power line that's dead, causing both the sound chip and the IDE controller to not function?
#198384 - 15/01/2004 12:46 Re: No Hard Disk Found - Contact Support [Re: tfabris]
mvigneau
Loc: Manchester, NH
I found a place that sells them. I have found someone at work that is willing to replace the chip for me (that's what they do).
I just want to make sure that this chip will work for me before buying it.
The minimum order is 5.90. I only need one. Is there another place to buy them or do you want to do a group buy? I am wiling to front the money. I am even willing to sell them at $5 each just to get rid of them. The minimum I need to buy is 7 to meet there minimum.
http://store.americanmicrosemiconductor.com/americanmicrosemiconductor/cs4231a-kq.html
Edited by mvigneau (15/01/2004 12:48)
#198385 - 15/01/2004 13:00 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
maczrool
Loc: Louisiana, USA
I'd be interested in a few if Hugo doesn't come through.
Stu
#198386 - 15/01/2004 13:06 Re: No Hard Disk Found - Contact Support [Re: maczrool]
mvigneau
Loc: Manchester, NH
Alright...I am going to order the seven and then there will be 6 left.
#198387 - 15/01/2004 14:15 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
I'll take one.
#198388 - 15/01/2004 14:22 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
Hope you already ordered...there's only 3 in stock now.
#198389 - 15/01/2004 14:59 Re: No Hard Disk Found - Contact Support [Re: maczrool]
maczrool
Loc: Louisiana, USA
I'll go ahead and commit to 3 if you can spare that many.
Stu
#198390 - 15/01/2004 15:18 Re: No Hard Disk Found - Contact Support [Re: JBjorgen]
mvigneau
Loc: Manchester, NH
Luckily I ordered my seven already. I should have just ordered the 10 of them but oh well.
#198391 - 15/01/2004 15:23 Re: No Hard Disk Found - Contact Support [Re: maczrool]
mvigneau
Loc: Manchester, NH
As soon as I get my player fixed, I will post the items up for sale in the For Sale section.
Edited by mvigneau (15/01/2004 15:26)
#198392 - 23/01/2004 11:54 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
maczrool
Loc: Louisiana, USA
Okay, well Hugo and or Rob? sent us a bunch of the CS4231A-KQs and a lot of other repair parts. So we've got them now. Thanks Hugo and Rob!
Stu
#198393 - 28/01/2004 12:22 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
mvigneau
Loc: Manchester, NH
Ok. I have replaced the CS4231A Chip. But it still is coming up with the No Hard Disk Found - Contact Support error.
It is now giving "Could not find CS4231A (version=c7)" instead.
What should I do?
#198394 - 28/01/2004 13:50 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
Try this version of Hijack, and report back here:
http://rtr.ca/hijack.v361+.zImage
#198395 - 28/01/2004 14:22 Re: No Hard Disk Found - Contact Support [Re: mlord]
mvigneau
Loc: Manchester, NH
I tried updating with the Logo Editor and after it completed, the standby light would just blink. I unplugged it and plugged it back in and still didn't work.
I reflashed the kernel to 2.0final and it gave "Error couldn't find pump occurred at stage 0x20" and now it just stays at the boot logo and never gets past it. Doesn't even come up with the No Hard Disk Found...Contact Support error.
Here is the output from HyperTerminal.
e000 v1.04
Copying kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #12 Tue Apr 1 18:51:41 BST 2003
empeg usb initialised, PDIUSBD12 id dfdf
#198396 - 28/01/2004 14:24 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
What is the output from hyperterminal with the version of Hijack that he just supplied to you?
#198397 - 28/01/2004 14:29 Re: No Hard Disk Found - Contact Support [Re: tfabris]
mvigneau
Loc: Manchester, NH
e000 v1.04
Copying kernel...
(data abort vector)
#198398 - 28/01/2004 14:34 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
Looks like your downloaded copy of that kernel that Mark supplied was corrupted. Try grabbing it again with a download manager program.
Mark, are you sure that kernel was good?
#198399 - 28/01/2004 15:04 Re: No Hard Disk Found - Contact Support [Re: tfabris]
mvigneau
Loc: Manchester, NH
I used the one from his website and am getting the same results as reflashing the kernel with 2.0 final. It stays at the boot logo screen.
Edited by mvigneau (28/01/2004 15:04)
#198400 - 28/01/2004 15:09 Re: No Hard Disk Found - Contact Support [Re: mvigneau]
I'm not talking about the one from his website. I'm talking about the one he linked above.
Look, lemme be absolutely clear on what's going on:
- You replaced the chip.
- The regular kernel (whether it's Mark's or Empeg's kernel) doesn't like the chip's version number. None of the normal kernels will work at this point, there's no sense in even trying.
- Mark made you a special custom kernel that he linked above which should (in theory) be happy with that chip's version number. He asked you to try it.
- You tried it but it doesn't work. From the serial output you displayed, it seems that there is something wrong with the file itself, for example, a bad download.
- Until you can get Mark's special custom-made-just-for-you kernel properly downloaded and installed so that it works with that particular chip, we won't know if Mark's fix worked or not. We need to get that particular kernel running properly on your player before we go any farther in the diagnostic process.
Get it?
