#199340 - 19/01/2004 11:54 Help.. :( hda: lost interupt
SE_Sport_Driver
My player locked up doing a sync at "Writing Player Configuration - Moutings Disks". I restarted the player and it started doing a database rebuild, but was taking way too long and not making any noises....
I tried it again (starting the player) and here is what I get....
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v352 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sat Jan 10 18:01:44 EST 2004
empeg-car player (hardware revision 9, serial number 30102609)
Command line: mem=16m
Memory: 15016k/16M available (976k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9bb84
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005f80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25T060ATCS05-0, ATA DISK drive
hdb: IC25N080ATMR04-0, ATA DISK drive
hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:3
1
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
hijack: removed menu entry: "Button Codes Display"
hijack: removed menu entry: "Button Illumination Level"
hijack: removed menu entry: "Calculator"
hijack: removed menu entry: "Font Display"
hijack: removed menu entry: "Show Flash Savearea"
hijack: removed menu entry: "Volume Level on Boot"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
Help.
#199341 - 19/01/2004 12:03 Re: Help.. :( hda: lost interupt [Re: SE_Sport_Driver]
Ooops.
Lost interrupts are usually a sign of a cable failure or dry solder connection...
#199342 - 19/01/2004 13:41 Re: Help.. :( hda: lost interupt [Re: pgrzelak]
SE_Sport_Driver
I took the drives and put them into my backup Mk2. (Those things come in handy huh?) I re-used the cable and it's booting up fine. Looking at the Mk2a that was giving me trouble, the pins are discolored a bit, but I don't think I see any dry connection. Maybe I need a magnifying glass?
Is contacting support my best bet? Am I going to pay through the nose on this? (Assuming it is a dry solder connection.)
PS - My Mk2 had no drives in it and had last run 2.00b11. I flashed it with the latest HiJack and put the drives that have 2.00final on them in. Am I missing a step? Do I need to reinstall 2.00final?
#199343 - 19/01/2004 13:48 Re: Help.. :( hda: lost interupt [Re: SE_Sport_Driver]
The lost interrupt error definitely indicates hardware failure with the disks or the IDE connection, and has nothing to do with the way you installed the software.
Yes, you might need a magnifying glass to see header solder joint problems. But that's not necessarily what's happening to you, it could be any number of things. Just go through the whole list of possibilities in the FAQ about hard drive trouble, and carefully investigate every one.
#199344 - 19/01/2004 13:58 Re: Help.. :( hda: lost interupt [Re: tfabris]
SE_Sport_Driver
Your FAQ was the first place I looked before posting. I didn't find any reference to "lost interupt" but I did check out the "no hard disk found, contact support" info. It appears that the cable and drives are fine since I did a complete swap of those to my backup player. That alone eliminates most of the probable causes. And since this was only on DC, car wiring or power issues are not at cause.
It's just weird how I've been sitting here syncing to the thing all day and suddenly it takes a crap.
I'll see if I can get a magnifying glass.
#199345 - 19/01/2004 14:01 Re: Help.. :( hda: lost interupt [Re: SE_Sport_Driver]
That could be temperature, then.
#199346 - 19/01/2004 21:47 Re: Help.. :( hda: lost interupt [Re: tfabris]
SE_Sport_Driver
After some painfully long media checks and fsck's, I had the drives working perfectly fine in the backup empeg. Then, just for shits, I popped the drives and cable back into the "problem" RioCar and it booted up fine...
So, Tony's suggestion of temperature being an issue seems likely.... The cable could have been loose etc, as well.
I'll keep everyone posted (if anyone cares) if I can replicate the issue on either or both players.
#199347 - 20/01/2004 05:45 Re: Help.. :( hda: lost interupt [Re: SE_Sport_Driver]
Keep in mind also that the cold solder problem first shows up when you have significant termperature swings. At least, that is how I first found mine.
