#200447 - 26/01/2004 03:44
Internal USB Card
I've posted about this before, but I still haven't been able to find the product I need. I also couldn't find the last thread on the subject.
I need a PCI card that has headers for USB ports that are already mounted in my case. I'm pretty sure that in my previous thread about this, Rob suggested this. However, besides the fact that it's a Soyo, it doesn't appear to be sold anywhere, and this has been the case since I last asked. I contacted the company, but that wasn't any help.
Does anyone know where I can find another card like this, or where I can buy this card?
#200448 - 26/01/2004 03:58
Re: Internal USB Card
I'm still puzzled by the requirement to expose the existing USB ports on a PCI card. Why don't you just get a PCI card with 4 new USB ports ?
#200449 - 26/01/2004 06:09
Presumably you're talking about one of those motherboards where it has, e.g, 5 USB ports, but only two of them are on the ATX panel, and the others are just headers on the motherboard?
My Asus board came with this kind of thing, but it included the relevant thingummy that you screw into a spare gap at the back (i.e. into the hole in the case, not actually into a slot on the board). It's effectively just a piece of metal with some ribbon cable attached to it.
So, assuming that this is what we're talking about, what kind of motherboard is it? Do they sell spare ones?
Alternatively, as andy says, USB 2.0 cards are relatively cheap, so you could just give up on the internal ones.
#200450 - 26/01/2004 06:32
There is one here but it's in the UK. It probably would just be easier to use a proper USB2.0 PCI card as you're going to taking up a slot anyway.
#200451 - 26/01/2004 08:14
Loc: Manassas VA
something like this or this?
Ebay... if your looking for something with usb headers (not jacks) just do a search for "USB PCI 2.0 header" if you want something internal that has actual usb jacks, omit the header part in your search. Theres literally thousands of cards.
Brett
60Gb MK2a with Led's
#200453 - 26/01/2004 09:17
[Re: robricc]
But from where can we get the headers (cables+jacks) to go with the two internal USB ports on that card, Rob?
#200454 - 26/01/2004 09:21
[Re: andy]
Many motherboards also have internal USB headers, and newer (mini)ATX cases provide internal cables & connectors for FRONT PANEL USB access via those headers.
Presumably what Roger wants, and me too, are those cable/connector assemblies, not yet another set of bloody useless rear-panel ports!
#200455 - 26/01/2004 09:24
Loc: Manassas VA
Brett
#200456 - 26/01/2004 09:26
If you really wanted to do that, you could get a bracket like this.
I would imagine Dignan wants to use the headers for something like an internal card reader.
#200457 - 26/01/2004 09:47
Nah, not me. I've already got the relevant doodad for my (Asus) Linux box. My (Windows XP) ShuttleX box has plenty of USB ports on it -- and I use a USB hub anyway, because most of my USB gear (printer, scanner, ...) is on the shelf behind me.
I'm just trying to find out what, exactly, DiGNAN17 is looking for, and what he plans to do with it.
#200458 - 26/01/2004 10:12
[Re: Roger]
Whoops.. yeah, not Roger, but the other guy!
#200459 - 26/01/2004 11:14
[Re: Roger]
Loc: Georgetown, TX USA
What brand and model USB hub do you use? I bought a cheapo powered hub that locks up my computer at least once a day when I try to use it.
Dave Clark
Georgetown, Texas
MK2A 42Gb - AnoFace - Smoke Lens - Dead Tuner - Sirius Radio on AUX
#200460 - 26/01/2004 11:35
[Re: davec]
Something from Belkin (an F5U021 according to the sticker on the bottom). Works fine. It's only USB 1.1, though.
#200461 - 26/01/2004 12:47
[Re: Roger]
As was mentioned, I want a card like this for the ports and cables that already exist in my case. Here's the math:
ASUS A7N8X mobo w/ 4 rear onboard USB 2.0 ports
1 header on the motherboard for 2 case-mounted USB 2.0 ports
4 actual case ports
6 working ports and 2 dead ones
I simply want to make use of the ports I have on the front of my case. However, there are several solutions listed in this thread, suprisingly. I did all kinds of searches, but wasn't successful. Well, I guess that's why this board is so great! I'd actually prefer something that only had internal headers, but I'll take the extra ones too, if I must.
By the way, I have that same Belkin USB hub, and it works great for me. Got it at Best Buy for $5 after rebate
