#202648 - 06/02/2004 08:17 Empeg boot log....what does this mean?
slammed2001sc2
Here is a copy of my boot log:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #12 Tue Apr 1 18:51:41 BST 2003
empeg-car player (hardware revision 9, serial number 10101299)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
ttyS00 at 0xf8010000 (irq = 15) is a
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
i2c: Failed to receive ACK for data!
i2c_write: device select failed
I2C write failed (fff, d223)
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005300).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Eri
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:1
3
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init player.cpp : 385:
03/04/01.
I2C write failed (927, 0)
I2C write failed (8f9, 90d)
i2c_write: address select failed
Vcb: 0x4086d000
Can anyone tell me what all the i2c errors are??? Is this related to the hard disks?
#202649 - 06/02/2004 22:21 Re: Empeg boot log....what does this mean? [Re: slammed2001sc2]
slammed2001sc2
Do these i2c errors indicate some sort of hardware malfuntion? From doing some searching on the forums, it may be my 74LVX04 chip that is the culprit?
#202650 - 06/02/2004 23:30 Re: Empeg boot log....what does this mean? [Re: slammed2001sc2]
Well, they certainly don't indicate that everything's peachy keen...
I haven't done a search for other instances of the error, but if you have, and if the search results turn up someone else with the same error, then I'd say that you've probably got the same problem he had (whatever that was).
#202651 - 07/02/2004 02:56 Re: Empeg boot log....what does this mean? [Re: tfabris]
slammed2001sc2
Well, I've found this old forum topic that deals with a similar problem....
#202652 - 07/02/2004 22:39 Re: Empeg boot log....what does this mean? [Re: slammed2001sc2]
Yep, from the looks of your error message, it's the same problem ClemsonJeep had. I don't know who in Cambridge fixed ClemsonJeep's problem, but if it was Hugo, then he could definitively answer if it was really a bad DSP or not.
In any case, it's a serious issue, it's one of the main pieces of digital circuitry that's failing. It's not something simple like a loose wire or a bad solder joint, we're talking about one of the main chips going bad here. The required repair is the empeg equivalent of open-heart-surgery.
Everyone send flowers and get well cards.
#202653 - 10/02/2004 00:29 Re: Empeg boot log....what does this mean? [Re: tfabris]
slammed2001sc2
So when you say a bad DSP you are talking about the CS4231A chip, right? Forgive my ignorance here, but I'm not too familiar with all the chips and whatnot on the Rio's mainboard. I have been in contact with Stuart from Eutronix and he seems to think that the CS4231A needs to be replaced.....sorry about all the posts, but I just want to make sure I've got the problem isolated and get my poor Rio working again!
#202654 - 10/02/2004 00:45 Re: Empeg boot log....what does this mean? [Re: slammed2001sc2]
Daria
mine toasted a 4231 last year. one day it was just dead.
#202655 - 10/02/2004 01:03 Re: Empeg boot log....what does this mean? [Re: Daria]
slammed2001sc2
dbrashear, what were your symptoms? Were you having any problems with the Rio prior to your 4231 failing?
#202656 - 10/02/2004 02:31 Re: Empeg boot log....what does this mean? [Re: slammed2001sc2]
Daria
Nil. Worked fine. The next morning my wife came in from the car: "it's dead". Sure enough, it was dead.
#202657 - 08/10/2004 12:01 Re: Empeg boot log....what does this mean? [Re: Daria]
genixia
Bumpity Bump.
According to the kernel sources, only the main DSP (SAA77H05) appears to use the i2c bus - the CS4231A uses an ISA interface.
It looks like either your DSP or its clock circuitry is fubar.
