#202715 - 06/02/2004 11:13 Lost many playlists and songs !!!!
dda
Loc: Belgium
Hi,
When restarting my player, I saw it doing a "rebuild database" and when I've started my Emplode I received a lot of "Initializing Warnings of Playlist lengths" and I saw that my playlists were completely scrumbled. When doing searches, I can't even find some songs anymore !!
Is there a way to find back my previous database organisation ?
P.S. : What I did just before was changing the field "khttpd_port=82" to 80 in my config.ini file with my Emplode but I didn't synchronise it. Could this be at the origin of this mess ?
Years of work are in the air. Is there an angel who could help me ?
#202716 - 06/02/2004 11:16 Re: Lost many playlists and songs !!!! [Re: dda]
Delete the database files, and do two more syncs. And call me in the morning.. (when my phone is OFF).
#202717 - 06/02/2004 11:33 Re: Lost many playlists and songs !!!! [Re: dda]
Check on this possibility first, then check to see if you are having disk drive trouble. If both of those things are OK, then check and see if you get e2fsck errors at the shell prompt, and finally, as Mark said, see if rebuilding the databases by hand fixes it.
#202718 - 06/02/2004 12:03 Re: Lost many playlists and songs !!!! [Re: tfabris]
dda
Loc: Belgium
Thanks for such a prompt answer.
Could you confirm if I have a disk problem (see here after) ?
If yes, I suppose that I have to open the box and check for the cables. And how can I see if the second disk is completely out of order ?
- My /drive1 directgory is empty !!!
- And this is an extract from my boot
Probing primary interface...
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:d
8
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 82
kftpd: listening on port 21
Vcb: 0x4086d000
DDA
#202719 - 06/02/2004 12:09 Re: Lost many playlists and songs !!!! [Re: dda]
I think this might be an indicator of the problem. Also, I think that your boot up sequence is showing that only the first disk drive is being detected. So yeah, if it's a two-drive player, then it looks like one of the drives might not be booting up. Time to open it up and check the cables, the jumper, and the IDE header. Also make sure you've got standoff washers on the drives and loctite the screws while you're in there. Make sure to carefully follow the disk upgrade guide for the disassembly instructions.
#202720 - 06/02/2004 13:37 Re: Lost many playlists and songs !!!! [Re: tfabris]
dda
Loc: Belgium
You're my angel Tony. Domo Arrigato, Mr. Riocaro.
I've opened the box. Didn't see anything special but plugged out the disk cable and plugged it in again. Closed everything and restarted the player. It found back the second drive and I found back all my playlists and song without any error message from Emplode.
Ouffffffffffff.
Let's have a dram of single malt to celebrate and let's try again to put this http port back to 80 in config.ini. This must be the source of the problem I've posted in the Programming thread to make your EmpegFace work. I don't remember why I've put this once on 82 but ...
