#203973 - 11/02/2004 18:31 IRC gateway?
Is there a such thing as an HTTP-based IRC gateway? Something that can be used as a front end to connect to an arbitrary IRC server/channel, but which doesn't require those specific ports to be open? For instance, such a product running on a public web server could allow someone behind a firewall to use IRC.
#203974 - 11/02/2004 18:40 Re: IRC gateway? [Re: tfabris]
Used to be two that I knew of way back when but they both got taken down due to bandwidth problems and abuse. No idea if there are any new ones.
Can't poke holes in your company's firewall?
#203975 - 11/02/2004 19:14 Re: IRC gateway? [Re: tonyc]
It's not my firewall that's the problem. It's for someone else.
#203976 - 11/02/2004 21:25 Re: IRC gateway? [Re: tfabris]
ricin
Loc: US: CA
Can they SSH out? If so, they could setup an ssh tunnel.
Windows OpenSSH can be found here.
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#203977 - 11/02/2004 21:28 Re: IRC gateway? [Re: ricin]
Tunnel to where?
#203978 - 11/02/2004 21:28 Re: IRC gateway? [Re: tfabris]
Heather
Loc: NY
feeling left out tony?
Heather
"I distrust those people who know so well what God wants them to do because I notice it always coincides with their own desires." -Susan B Anthony
#203979 - 11/02/2004 21:30 Re: IRC gateway? [Re: tfabris]
ricin
Loc: US: CA
To any machine they can SSH to.
I figured there has to be a friends machine they can use, or something. Or, no?
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#203980 - 11/02/2004 21:35 Re: IRC gateway? [Re: tfabris]
Honestly, it's not mine! IRC isn't my bag, baby! Someone must be playing a prank on me!
#203981 - 11/02/2004 22:32 Re: IRC gateway? [Re: ricin]
lectric
Loc: New Orleans, LA
I use ssh tunnels all the time. I tunnel from work to home and forward all the ports I need. Since I have full control over my home firewall, but have to be careful at work, this helps out a LOT. Of course, sshd is running on cygwin on a 2000 box. Works like a champ. The only drawback is the abysmal upload speed I get at home.
#203982 - 11/02/2004 22:39 Re: IRC gateway? [Re: tfabris]
SE_Sport_Driver
Tony, are you talking about something like this?
#203983 - 11/02/2004 22:41 Re: IRC gateway? [Re: Heather]
Heh, no. Actually, I can IRC whenever I feel like it, I just don't do it that often. I'm serious about this being for someone else. He's a fellow filker that sometimes wants to get to the filk channel.
#203984 - 11/02/2004 22:52 Re: IRC gateway? [Re: SE_Sport_Driver]
Not sure just yet. It depends on how that applet works.
If it's a java applet which is merely a java replacement for MIRC (in other words, the communication still happens with your local machine using the IRC ports that get blocked by firewalls), then no.
If it's a front end that uses HTTP to communicate with the chrismyden.com server and then something on the server talks to the IRC servers using the "naughty" ports, then yes.
Can't tell right off the bat which of the two this is. I suspect the former.
#203985 - 11/02/2004 22:54 Re: IRC gateway? [Re: tfabris]
SE_Sport_Driver
I know that applet will let you specify IRC server and room name... so it doesn't need to connect to chrismyden.com. It has been years since I used his chat room to learn about EAC, so I don't have any current experience with it..
#203986 - 11/02/2004 23:00 Re: IRC gateway? [Re: tfabris]
Terminator
Loc: Dallas, TX
