#204729 - 15/02/2004 19:57 Make 4 button on remote access bookmarks
jim_55063
I've been going over the hijack faq but haven't been able to find the information I need. Is there a way to use ir translate to make the 4 button on my Rio remote access the bookmark menu or even select the bookmarks in order??? I find it tedious to go through the different menu's to get to the bookmarks. Anyone have any idea's??
#204730 - 15/02/2004 20:28 Re: Make 4 button on remote access bookmarks [Re: jim_55063]
You could make it so that it opens the main menu and presses a number key that corresponds to the "Bookmarks" menu. So it would IR translate to downbutton then <number> (whichever that number is). I don't have the empeg plugged in right now so I don't know which number it is. But every menu has a shortcut number, and they go in order. 1 is the first menu, 2 is the second menu, etc. Mess with it and find out which one it is, then program your IR translate to change the remote's 4 button to <down> <number> and then that'll get you to the bookmarks menu.
#204731 - 15/02/2004 21:15 Re: Make 4 button on remote access bookmarks [Re: tfabris]
jim_55063
Well the 4 button on the remote gives the code: 20df04
So I know that using config.ini it would start like this
[hijack]
[ir_translate]
20df04=
I also know the bottom button on the mp3 is code: 6 and the bookmark menu is like 7 places to the right inside the main menu so what would the finished config.ini look like??
#204732 - 15/02/2004 22:35 Re: Make 4 button on remote access bookmarks [Re: jim_55063]
cushman
Loc: Erie, CO
Look at this thread. Examples inside.
Mark Cushman
#204733 - 15/02/2004 23:38 Re: Make 4 button on remote access bookmarks [Re: jim_55063]
[ir_translate]
Four.M=Menu,Seven,Menu
EDIT: added the .M above..
Edited by mlord (15/02/2004 23:40)
