Emplode has 'Reset Metadata' command on the right-click context menu that will reset the tunes bitrate, duration, offset, and samplerate. It asks you if you are sure you want to clear these before doing so. Then at the sync it clears thems and notices they are empty after reloading the rebuilt database. Could you add that command to JEmplode?
And while you're at it
Could you create a 'Reset Statistics' command too? It would be nice to be able to zero out the play_count, play_last, and skip_count stats when needed. I've tried doing this on the advanced properties tab but for some reason it doesn't work 100% of the time.
Thanks,
-Chuck
