#207621 - 28/02/2004 09:01
Yay, my new install is done! But...
Loc: Squamish, BC
They've screwed something up. In my old car, when you removed the key, the empeg used to switch off, but would switch on sans-key if you just pressed the on button.
In this car, you remove the key, the thing makes an almight 'pop' and the empeg is totally without power.
Any ideas?
#207622 - 28/02/2004 09:24
Re: Yay, my new install is done! But...
[Re: snoopstah]
If it is going in a VAG car they are bastards as they have normal iso connectors but i think the switched live and permant feed are swapped therefore you are cutting power completely to the empeg when you switch it off.
Aberdeen Scotland
#207623 - 28/02/2004 09:26
[Re: thinfourth2]
Loc: Squamish, BC
Ahh yes. Forgot about that. Any idea which two wires I need to swap on the dock harness (i.e. which colours ![](/images/icons/wink.gif) )?
Edited by snoopstah (28/02/2004 09:27)
#207624 - 28/02/2004 10:00
[Re: snoopstah]
Loc: Tucson, AZ
Orange and yellow.
Steve
#207625 - 28/02/2004 10:22
[Re: snoopstah]
Please make sure to read the relevant FAQ entries here, here, and here.
#207626 - 28/02/2004 10:28
[Re: lockuplever]
Loc: Squamish, BC
OK, I swapped those two around (easily done, fortunately) but now the player doesn't switch off when I remove the key! I have to manually switch it off.
Ideas?
#207627 - 28/02/2004 10:43
Loc: Squamish, BC
Right. Turns out I had two problems - it was wired incorrectly, and I have the stuck AC switch issue. I actually knew I had that, but it's been so long since I've had it in the car I completely forgot!
Thanks Tony and everyone else!
#207628 - 28/02/2004 14:12
[Re: snoopstah]
Loc: AC, Germany
Hi, and congrats for the car! (BTW: 5 or 6speeder?)
I chime in, because I think the colors are Brown/red and Red; at least that's the cables I swapped on the car's ISO connector; if you swapped the cables on the empeg sled then I have to admit that I don't know which ones you'll have to swap.
In my Lupo I did it wrong the first time, and then the empeg never behaved the way it should have when taking the key off....i noticed 2 months later that the 5A radio fuse in the Lupo was gone...since then, no problems!
#207629 - 28/02/2004 14:20
[Re: Lupo]
Loc: Squamish, BC
One of the first six-speeders. Fantastic little car! Is yours a GTI?
#207630 - 28/02/2004 14:31
[Re: snoopstah]
Loc: AC, Germany
Hehe, I had the joy to test-drive one for one afternoon; it's just so amazing, in every way!
I have the 1.4 tdi three cylinder, which is quite amazing for its low "thirst" :-)
#207632 - 29/02/2004 09:37
[Re: snoopstah]
Loc: AC, Germany
Not yet, i'm looking for a turbine swap...
#207633 - 07/03/2004 08:21
[Re: snoopstah]
Loc: Dallas Texas USA
Ahh.. I have the same problem. I never really thought about it as being a problem, I figured thats just the way it was. Good to know that I can swap a couple of wires and fix that. It is annoying.
Carl Aydelotte
Dallas Texas USA
empeg MKII 080000506 40gb-green
