#208061 - 03/03/2004 16:46 IP address
Qtqc
Im trying to put the TTS Clock addon on my player. Im having trouble finding my players IP address. Any help woulb be appreciated. BTW I have it hooked up on USB if that matters
#208062 - 03/03/2004 16:50 Re: IP address [Re: Qtqc]
Daria
choose "about" from the top level menus and scroll down.
#208063 - 03/03/2004 17:11 Re: IP address [Re: Qtqc]
If it's *only* hooked up with USB, then it doesn't have an IP address. You need ethernet for that...
#208064 - 03/03/2004 17:18 Re: IP address [Re: Qtqc]
Qtqc
The instructions only metion using an IP address for install. Would there be a way to install using USB
#208065 - 03/03/2004 17:35 Re: IP address [Re: Qtqc]
Daria
Nope.
#208066 - 03/03/2004 19:17 Re: IP address [Re: tfabris]
SE_Sport_Driver
On a very loosely related topic... here is my paste from my config.ini file:
[Network]
Gateway=0.0.0.0
Netmask=255.255.255.0
IPAddress=192.168.0.4
DHCP=1
Yet, on a P2P network (notebook to empeg via crossover cable), my empeg always picks its own IP. I know it's failing to get a DHCP signal, but I thought that line in my config where I specify my IP would take over..
#208067 - 03/03/2004 21:22 Re: IP address [Re: SE_Sport_Driver]
Nope, that's not how it works. All other lines are ignored if DHCP=1. The player is designed to assign itself a UPNP address if you tell it to use DHCP and there isn't a DHCP server.
#208068 - 03/03/2004 21:26 Re: IP address [Re: Qtqc]
There is no way to add files to the player using USB, however you can use the serial cable.
By the way, since you seem to be a newbie at this, I want to remind you to use the @DC modifier if you install any programs that run off of the /drive0 or /drive1 partitions. If you fail to do so, your player will be unable to synch because it won't be able to mount the music partitions correctly, as described here.
